Results 1 to 4 of 4
Thread: Ahhh What do I need?
    mykwikcoupe and I are going to replace my inner tie rod ends. I'm on Majestic
    http://www.hondaautomotiveparts.com/...tcgry5=TIE+ROD
    and I have no idea what I need... at all! My mechanic just said "play in inner tie rod ends", so what should I get? What quantities?
    THANKS
    shepherd79's Avatar
    Falling Waters, WV USA
    are you sure it is the inner tie rod.
    the way you can check it if you raise the car on one side and try to move the that wheel right to left. if you can fill the free play, i would say it is your outter tie rod.
    Moodybluesr's Avatar
    Jan 2004
    1991 Subaru XT6 AWD, 1988 Subaru XT6 AWD
    Urbana, IL
    In that schematic number 9 is your inner tie rod end. To replace the inner tie rod, you are going to either need an inner tie rod end tool or a crow's foot (not sure which size) and a long extension (preferably 24"). As long as you have the right tools, it really isn't that difficult of a job. Since the outer tie rod end has to be removed during the procedure and they are relatively inexpensive, you may look into replacing them at the same time. Also, check the boots before you go buying parts. If they are cracked, you are going to want to replace those as well.
    My mechanic was nice enough to outline the parts I need and give me a price. I went to Shucks and they want 90 bucks for inners and outers with all the associated nuts and washers and crap. I figure what the hell, I'll go to Shucks.
    Thanks for your help.
  1. Ahhh Vibrations
    By Brentm in forum 3geez Accords
    Last Post: 02-27-2004, 07:51 AM
  2. AHHH!!! my dashboard light!!
    By ShawnS in forum 3geez Accords
    Last Post: 04-06-2003, 10:15 PM
  3. Ahhh, trunk space.
    By pearldrop in forum Classic Honda Pics & Videos
    Last Post: 01-17-2003, 07:30 AM
  4. ahhh rust!!!
    By Defiant[YD] in forum Suspension/Wheels/Tires/Brakes
    Last Post: 12-29-2002, 03:22 PM
  5. Lights >>ahhh >>>help!!! Seriously!!!
    By MyGarbageLXi in forum Interior & Exterior Care
    Last Post: 12-07-2002, 09:32 PM
