Results 1 to 11 of 11
Thread: Whats the best carb cleaner
    Nov 2003
    89 Honda Accord ex
    Canada
    What works best the spray can or the kind you add to your fuel?Also i'm planning on trying the spray how are you suppose to use this spray it in the carb while the car is running someone help me out please.
    1987 Hatchback phreak project
    NORTH BAY ONTARIO
    buy some carb cleaner at canadian tire or somthing.. then read the instructions on the back of the can.. dont waste time and money on fuel additives
    Travis
    Nov 2003
    89 Honda Accord ex
    Canada
    Thanks i'll check crappy tie tommorow.
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    I used GUMOUT carb and choke cleaner
    You can spray it while the car is running but I would do the the first application while the car is off so the cleaner has time to work... if the car is on most of the liquid will get sucked in.
    They also have foam cleaners, not sure who makes em though.
    if there is lots of buildup on the throttle plates you might consider removing the carb to clean... or get a pipe cleaner brush and srub the plates down.
    Also after replacing you fuel filters and letting the car run for a while you should open the top of the carb and whipe out the float bowl. Try not to mess with the float or float screw while cleaning the bowl.
    Jan 2004
    86 Accord LXi hatch, 04 Silverado 1500, 99 Malibu
    UT
    How often should you spray out your carb? I use mine to drive to work everyday, 30 miles each way on the freeway.
    NORTH BAY ONTARIO
    is it running rough? have you done it in the past 10 000 miles? its worth a try.. never know what will happen
    Travis
    Nov 2003
    89 Honda Accord ex
    Canada
    I haven't done mine since i got the car and that was in august so who knows if the last guy did it at all.
    LX User skull1441's Avatar
    Dec 2003
    1988/Honda/Accord DX 5-speed and 1990 300zx N/A 5-Speed
    Memphis, TN
    does spraying it help reduce emmissions???
    NA>TT Underway
    k-roy's Avatar
    87 LX
    Quote Originally Posted by skull1441
    A little bit. If I was prepping a car for an Echeck I would do this.
    Nov 2003
    89 Accord LX-i
    Space Coast Florida
    I have used several, but always seem to get the best results with Valvoline carb/injector cleaner...it comes in a fairly big can, and a good spray applicator, and it cleans like a mo-fo !!!...the only thing I would put in my gas tank is methyl hydrate (gas line antifreeze), to disperse water in the tank, and in your case, the carb float bowl.
    My other Honda has 2 more cylinders, and 2 less wheels.
    Carb-medic will clean what gumout won't. Its banned for sale in california
  1. carb cleaner fixed my problem while i was spraying it
    By bwallace530 in forum Carburetor Tech
    Last Post: 04-04-2009, 08:43 AM
  2. Help! Whats the grill? Whats that black bar behind the bumper?
    By Dennis in forum Interior & Exterior Care
    Last Post: 08-19-2007, 09:55 PM
  3. Carb Cleaner and Fuel Treatment
    By HondaBoy in forum Performance
    Last Post: 05-22-2004, 07:59 AM
  4. Carb. Cleaner Spray Seems To Realy Work
    By HondaBoy in forum Carburetor Tech
    Last Post: 11-02-2002, 11:51 AM
  5. Carb cleaner
    By s0crates82 in forum Carburetor Tech
    Last Post: 06-23-2002, 12:08 PM
