I tried putting my 5-spd starter in only to here it spin freely. It was obvious to me that this was not the correct starter. I did a search here on the boards and found one thread that said to use an automatic starter, and that the manual one woundn't work. So my first questions is... Which Starter do I buy?
1. Nippondenso Type
2. Mitsuba Type
Also, what is the difference in the two?
Now for the coolant lines...I see that the coolant lines on my carb manifold are totally different than the pipes on the B20A (probably because the B20 I have was an FI motor). Has anyone converted these yet? I'm not sure what to do here. I kept the distribution tube that runs from the water pump just in case I have to swap it out. Any ideas on how to set these up? I'll take some pics tomorrow if you need.
Thanks... Jose'
