Results 1 to 3 of 3
Thread: Brake lights and other tech problems
    Jan 2004
    87 Accord lxi 5spd hatchie/84 accord lx 4-dr/74 dodge dart
    Escondido,Ca(San Diego)
    My brake lights don't work.My tail lights blinkers and reverse
    lights all work but my brake lights don't.I have replaced the brake switch...nothing...checked the fuse...still good.(probably checked the wrong one though)Anyway I need help before I get a fix-it ticket!Also,how do I reset my ECU after fixing my EGR lift sensor?
    I'm a mushroom cloud layin' mutha fu**er,muthafu**er--Samuel L. Jackson in Pulp Fiction http://www.cardomain.com/id/mattalica13
    k-roy's Avatar
    87 LX
    You should probably check all the fuses if you are not positive you checked the right one.
    Did you check the bulbs themselves?
    To reset the ECU disconnect the battery for a couple of minutes.
    SEi User BMS's Avatar
    Nov 2002
    88 LX / 97 Teg
    California
    If it were just the bulbs burnt out then the light would come on the little car on the dash. And not all of them should ever go out at once.
  1. Brake Problems...
    By AccordAddict in forum Performance
    Last Post: 09-07-2004, 04:07 PM
  2. e-brake problems
    By rdn in forum 3geez Accords
    Last Post: 06-07-2004, 11:01 AM
  3. anyones brake lights also turn on your dash lights?
    Last Post: 03-07-2004, 01:31 AM
  4. Replies: 22
    Last Post: 02-16-2004, 04:03 PM
  5. brake problems
    By seancornelis in forum 3geez Accords
    Last Post: 12-09-2003, 11:17 AM
