Page 2 of 2 FirstFirst 12
Results 26 to 40 of 40
Thread: lxi dyno'd stock and w/intake
    86AccordLxi's Avatar
    Oct 2000
    1989 240sx FB,
    Salem, OR
    Uh...it's not 114 at the wheels, it's at the crank. All cars' hp ratings from the factory are rated from the crank.
    Alex
    lol. okay man wat ever u say. maybe my car just in good shape and has the power. or something. when i bought the car from the owner he had dyno slips saying my car had over 114 at the wheels. he said the motor was worked on a little. thats what my friends say to. but i guess watever. late
    Oct 2000
    1989 240sx FB,
    Salem, OR
    If your motor was worked on a little, then it's not stock, is it?? So a stock car probalby wouldn't be making 114 whp as your 'worked on' motor would, would it?
    In any event, cars from the factory have a hp rating taken at the crank, thus disproving your all-knowing friends.
    Alex
    LXi User BensAccordLxi's Avatar
    1995 Eagle Talon TSi Turbo
    Tucson, Arizona
    I bet over half the board would be under 100hp even with a 5spd. The car has 120hp or so stock, add 130K or more and you are far from the stock hp. It all depends on how the car was driven during its life time. A million things go in to the numbers a car will put down. I say it's not bad. Keep going with it.
    R.I.P. 1988 Honda Accord LX-i hatchback
    Justin86's Avatar
    Medford, Oregon
    well that is stock so lets see a lot more mods added then some more dyno results.
    Hey modu03 if you think your exhaust you should hear mine. Everyone that has heard it says it is the loudest. I had to put a glass pack on to make it closs to the legal limit but I still get pulled over every week for it. Before with uncapped header I got pulled over 4 times in one night. :cool2:
    10/Honda/Ridgeline
    NJ
    You might as well get the 88-89 intake manifold if its compatable with the 86-87 block and emissions. I think it might be compatable, but do check it out. Im hoping to push around 140hp if i can after the work done to this car with the intake, full exhaust with 2.25" pipes and full fuel system. Im just waiting for the 550 cc injectors and the O-ring kit. I should be able to get those numbers soon. If not, a cam should come in handy. ANd yeah 93 Octane is my best friend now.
    Justin86's Avatar
    Medford, Oregon
    Quote Originally Posted by smufguy
    Yea I swaped the 89 intake, had to mess with the wiring harness and change the emission box but everything works fine. Then if you don't have emission you can yank that stupid emission shit and still have the car idle good. I did some research and figured out how to do it so I pulled the emissions and the (A/C idle control selonid 86-87EFI only)
  8. #33
    SEi User racerx's Avatar
    May 2003
    87 Honda Accord DX
    Colorado Springs
    Quote Originally Posted by modu03
    uh... pacesetter... quiet... ya, I set off car alarms with my pacesetter exhaust, not as easily as I did when I had no muffler, but the pacesetter is not a quiet muffler. I am actually thinking of cutting it off and popping in something a little less noisy. I have not seen people complaining about how quiet that system is. I should get a recording of my exhaust and post it.
    dude, where have you been? try searching... if you think the pacesetter muffler is "loud" than you're just kidding yourself, or you have way overly-sensitive hearing. yeah it will grumble pretty good in the lows rpms, but that's about it.
    its okay dude, nobody's gonna make fun of you for not having the loudest exhaust system available.
    www.stein-photo.com
    born to XLR8
  9. #34
    Jan 2004
    What muffler is that ?
    Quote Originally Posted by Cyric_accord
    If you think that the tip makes no difference, you're dead wrong.... lemme drive my car to you... The tip on my quiet, stock muffler was shorn off somehow and now it sounds like your typical fart-can civic, with a slightly deeper tone between 2-3.5k rpm, then you can't hear it cause engine noise takes over.
    But the tip can make a difference, i know... thus my new muffler
    Hey what muffler is that. I just got my accord and it has a typical fart-cat system like you mentioned and I would like to switch that out with something quieter but allow the air flow for the horsepower.
  10. #35
    87 Lxi Hatch<-Blown Up!! 96 civic coupe
    Hot, Sweaty Florida
    I need to dyno mine! I think im pulling about 105hp @ the wheels!! W/o the bottle!!
    Cold Air intake, Apexi N1 turbomuffler w/2.25 piping, H22 injectors,gutted cat, Dc sport header, accel coil, MSD ignition, Dropzone coilovers
  11. #36
    LXi User Cyric_accord's Avatar
    Jul 2003
    95 Skivic
    Madison, Wisconsin
    Quote Originally Posted by zerotap
    It's an MAD Racing Concepts N14 Stainless Steel muffler, got it on Ebay... here's another one for ya: http://cgi.ebay.com/ebaymotors/ws/eB...tem=2458200451
  12. #37
    10/Honda/Ridgeline
    NJ
    Quote Originally Posted by Kevin
    how much does the h22 injectors flow? like 230 cc or somethin? besides, 105 whp is pretty good. what kinda pipe u got?2.25" and how about the fuel system besides the injectors?
  13. #38
    Jan 2004
    I'm not doing a 88-89 intake manifold because I have a b16 manifold sitting in my garage all re-drilled and ready to install. I think I"m going to do the cam first, then the intake manifold. Don't worry there will be more dyno's to come. 86hp is just a starting point
    87lxi 4door auto 86whp/all motor!
    95 del sol b17a turbo 207whp/7psi
  14. #39
    Dec 2003
    Millington, TN
    We'll be waiting.
    Thanks for the info, always good to have a base line to know what gains or losses your getting.
    Thanks again,
    Phil
  15. #40
    Hot, Sweaty Florida
    The H22 injectors flow 310cc!! I have a full msd ignition box setup. No other fuel mods.My exhaust is custom 2.25 gutted cat and Apexi muffler!! IT has no internals or heave duty clutch!! It has been 16.1 @ 84 with a 2.3 60' <--last week!! With a good launch it should break 15.8 w/o the bottle!!
  1. Dyno Video From Tunerfest (Dyno Idiots)
    Last Post: 08-28-2007, 08:12 AM
  2. FS: Stock Intake from LXI
    By Nate2310 in forum Trading Post
    Last Post: 04-05-2004, 01:11 PM
  3. F/S stock intake
    By lightbulblxi in forum Trading Post
    Last Post: 04-04-2004, 11:25 PM
  4. Stock dyno chart....anyone?
    By othick in forum Performance
    Last Post: 01-20-2004, 03:01 PM
  5. SoCal dyno results (b20 dyno! vs a20 dyno!)
    By wickedaccord in forum Classic Honda Community Chat
    Last Post: 04-19-2003, 07:25 AM
