Results 1 to 25 of 40
Thread: lxi dyno'd stock and w/intake
    Well I just got back from the dyno. I must say it was the most fun I've ever had dynoing a car and the people there got a kick out of it. The car is a 87lxi 4 door auto (110hp stock). I just bought it and haven't even driven it home yet so it's in "as is" condition.
    Here are some highlights since my scanner is not hooked up
    Dyno 1:
    2500rpm - 44hp/94tq
    3600rpm - 64hp/96.6tq (peak tq)
    4500rpm - 80hp/94tq
    5400rpm - 86.8hp/84tq (peak hp)
    6700rpm - 66hp/52tq (rev limiter)
    Dyno 2:
    83hp/94tq (car getting hotter)
    dyno 3:
    added an intake and made 86hp and 96tq again, so maybe the intake got me 3hp, or maybe 0hp? But I came in with 86hp and left with 86hp. My next mod is either a b16 intake manifold or a cam depending on when colt sends me my cam back. I do know there is a lot of room for improvment in the high rpm's because at about 5000rpm the torque curve nosedives and a better flowing manifold or cam would help a lot. I will have a friend post the actual graphs once I get some more stuff done.
    87lxi 4door auto 86whp/all motor!
    95 del sol b17a turbo 207whp/7psi
    k-roy's Avatar
    87 LX
    You really need exaughst work with a header if you want to start making power.
    A header I will do but the exhaust has to stay quiet. I might do 2.25" mandrel bent pipes up to a 2.25" stock muffler I don't want this car loud.
    if you want stock sound, get dynomax superturbo. it is high flow muffler, but if you use 2.5" exaust tip it will sound just like stock.
    make sure you keep some kind resonator or it will sound a little louder.
    1987 Hatchback phreak project
    NORTH BAY ONTARIO
    run 2.5 inch pipe to a cheap stock tone replacement muffler with 2.5 inch pipes
    Travis
    SEi User racerx's Avatar
    May 2003
    87 Honda Accord DX
    Colorado Springs
    just use the pacesetter cat-back. it wont be 2db's louder than stock. trust me, i know.
    everyone keeps complaining about how annoyingly quiet that system is.
    the plus, though, is that it is still 2.25" and will improve your power as much as any other cat-back.
    i would not recommend the dynomax muffler! that is the recommended alternative to pacesetter because its alot louder.
    a tip will not make hardly any difference in sound. i mean come on, you dont hear an ominous roar coming from the back of a geo metro with a 4" tip from Pepboys, do you?
    www.stein-photo.com
    born to XLR8
    NXRacer's Avatar
    86 LXi Hatch
    Tri-Cities, WA
    thats pretty depressing to see those numbers......even more incentive to BOOST!
    Nothin' 2 Old Racing
    1988starter
    Guest
    Quote Originally Posted by racerx
    After I cut off the pacesetter muffler and added a dynomax there was a very nice power gain I felt Almost nothing with the pacesetter.
    LXi User Cyric_accord's Avatar
    Jul 2003
    95 Skivic
    Madison, Wisconsin
    If you think that the tip makes no difference, you're dead wrong.... lemme drive my car to you... The tip on my quiet, stock muffler was shorn off somehow and now it sounds like your typical fart-can civic, with a slightly deeper tone between 2-3.5k rpm, then you can't hear it cause engine noise takes over.
    But the tip can make a difference, i know... thus my new muffler
    LXi User BensAccordLxi's Avatar
    1995 Eagle Talon TSi Turbo
    Tucson, Arizona
    I only made 96hp and 111 ftlbs of torque with intake, muffler, and 6al ignition.
    R.I.P. 1988 Honda Accord LX-i hatchback
    2.0Si User lightbulblxi's Avatar
    Aug 2003
    88 accord lx-i coupe 5sp.
    pulaski wisconsin
    yea man, thats pretty low.
    -Brian
    My Accord
    Jul 2003
    95 Skivic
    Madison, Wisconsin
    Quote Originally Posted by lightbulblxi
    Well you realize that you lose horsepower to your accessories and from the transmisson as torque and horsepower is put to the wheels.
    so to only lose ~24 horsepower isn't all that bad, some cars lose close to 50 horses from the crank to the wheels.
    86AccordLxi's Avatar
    Oct 2000
    1989 240sx FB,
    Salem, OR
    But those cars are starting out with more to begin with. You lose a percentage of power to parasitic loss, so obviously with more power, the same percentage lost will equal a loss of more total hp.
    Alex
    Tucson, Arizona
    After I got the new tranny, ACT stage 2 clutch, Cam, Header, Blaster SS coil, and MSD 8.5mm wires I put down 124hp and 118 ftlbs. It helped to have the valves adjusted after each dyno run.
    May 2003
    87 Honda Accord DX
    Colorado Springs
    Quote Originally Posted by 1988starter
    really?? i wouldnt think so... but i guess the dnyomax must be a bit straighter than the pacesetter... who knew?
    Quote Originally Posted by Cyric_accord
    mm-hmm... well, in my experience (and my friends') it has not made any difference. perhaps when your tip got "shorn off" the muffler took some damage too and there's a hole somewhere. or maybe there's a hole in your piping... if all there was to sound was the tip, then hardly anyone would bother with a muffler at all, dont ya think?
    i dont know. i guess anythings possible...
    btw, your new muffler looks PHAT!
    www.stein-photo.com
    born to XLR8
    Idaho
    Those scores=poopy!
    1988starter
    Guest
    The pacesetter exhaust is crap when tested by grassroots it barely gained more that 1 HP when a crimp bent dynomax was tested on the same car same pipesize it gained 4.1 HP
    Hey I know those numbers suck, but really think about. 110hp and an automatic transmission. I wouldn't doubt if the auto tranny lost 20% of the power, then your looking at 88whp. This car has 137k on it and was not only stock but god knows when it was serviced last. On the other hand if you had an 88lxi (120hp) and a 15%-20% loss with a 5spd you could see 96-102whp stock. Look at bensaccordlxi, he made 96whp.
    Btw-bensaccordlxi what cam did you run? Did you dyno your car at apex? I've seen you around town, I think once you tried to race me in my silver ae86 and I thought that your car actually looked a lot like an ae86. 124hp is pretty good for that motor, have you run at the track? I'm taking my del sol saturday morning.
    Idaho
    That's why you need to do a 5 speed swap and quit giving exuses.
    All in time! I haven't even gotten it home yet. Seriously I've done my share of 5spd swaps and going to the junk yard, pulling a 5spd/clutch/flywheel/axles/pedals/shifter/cable...etc. Just a pain, then putting it in, it would take all weekend! I think I should just turbo it and let the auto tranny explode first, that would be more fun. Besides I love to break things. You should have seen us bouncing off the rev-limiter laughing at the dyno. I thought the whole car was going to explode. Anyway bitesize I saw your write up on your swap and it looks pretty straight forward, lots of good info. I like how you fit under your dash, too bad I'm 6'2"
    Compression check?
    Idaho
    Yah it was fun!!
    LX User foobari's Avatar
    Aug 2003
    1988 Honda Accord 2.0i-16 DOHC (RIP)
    Turku, Finland
    I made 124hp to the wheels, transmission losses were 20hp totalling 144hp at the crank.
    https://www.3geez.com/showthread.php?t=27388
    It's not the type of car you drive... it's the size of the arm hanging out of the window.
    Honda Accord 2.0i-16 B20A2 (R.I.P)
    Jul 2003
    87 accord lxi hatch (FI) stolen :(
    chico,ca
    uh... pacesetter... quiet... ya, I set off car alarms with my pacesetter exhaust, not as easily as I did when I had no muffler, but the pacesetter is not a quiet muffler. I am actually thinking of cutting it off and popping in something a little less noisy. I have not seen people complaining about how quiet that system is. I should get a recording of my exhaust and post it.
    87 hatch (stolen)
    88 lxi 4dr, 5spd, threw a rod... in process of swapping engine from my 87 hatch (police recovered what was left of the car).
    the fucker that sold me the 88 is lucky he lives 500 miles from me...
    ATHICK is your car Auto. if it is thats why your scores are so low man. manual suspose to be 114 at the wheels 4500 RPMS.
  1. Dyno Video From Tunerfest (Dyno Idiots)
    Last Post: 08-28-2007, 08:12 AM
  2. FS: Stock Intake from LXI
    By Nate2310 in forum Trading Post
    Last Post: 04-05-2004, 01:11 PM
  3. F/S stock intake
    By lightbulblxi in forum Trading Post
    Last Post: 04-04-2004, 11:25 PM
  4. Stock dyno chart....anyone?
    By othick in forum Performance
    Last Post: 01-20-2004, 03:01 PM
  5. SoCal dyno results (b20 dyno! vs a20 dyno!)
    By wickedaccord in forum Classic Honda Community Chat
    Last Post: 04-19-2003, 07:25 AM
