Results 1 to 7 of 7
Thread: valves
    Oct 2002
    2 87 accords 1 dx & 1 lx-i both hb
    tenn.
    Question valves
    what kind of valve spring compressor do you use on a B21 head?????????
    NXRacer's Avatar
    86 LXi Hatch
    Tri-Cities, WA
    the same as you would use on any other valve spring. There are a few different styles, just look to get one that can fit around all the valves because it could be a tight fit. Pretty much any compressor should work though.
    Nothin' 2 Old Racing
    Oct 2002
    tenn.
    no the one i have wont fit in between the head and the side of spring
    Jul 2003
    1989 Accord DX coupe, 1989 Accord LX coupe, 2002 Chevrolet Cavalier coupe, 2003 Subaru Impreza WRX STI
    Sherman, TX
    I have one that uses the bottom of the head for leverage.
    DX User ET2's Avatar
    Jan 2004
    The best one's are still the old bar type one's, use one of the bolts from the rocker arms to hold the end in place, hell of a lot better then those clap on things that keep's sliding off the springs f-in hate those
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    I like the C-clamp ones, you have to remove the head to use it though.
    shepherd79's Avatar
    Falling Waters, WV USA
    C clamp ones are the best.
    you can rent the regular valve spring compressor, but it is pain in the ass to use it.
    what are you doing with B21 head if it is not a secret?
  1. B20 valves
    By rjudgey in forum JDM B18A / B20A Swap Tech
    Last Post: 07-26-2006, 01:55 PM
  2. Thermo valves?
    By soljaboy2000 in forum 3geez Accords
    Last Post: 01-17-2004, 04:57 PM
  3. valves
    By tyne89 in forum 3geez Accords
    Last Post: 11-11-2002, 01:14 PM
  4. Valves
    By rallyeNate in forum 3geez Accords
    Last Post: 09-09-2002, 12:16 PM
  5. bent valves?
    Last Post: 07-30-2002, 02:57 PM
