ive read on here before (i search and couldnt find) about putting higher cc injectors in our cars from a prelude i believe. does anyone know which ones those are and what they came out of? i thought it was like a 94 prelude si H22, is this true?
why do you want bigger injectors?
do you have turbo? is your engine moded to the point where you need bigger injectors?
the stock injectors will do just fine for mild modification.
Bigger injectors will just make you run rich. You need some serious mods to accomidate them.
i have an intake, header with open exhaust, a chip, and a fuel regulator was about to put i H.O. fuel pump. i was just wanting a little lager injectors, i just want a little more fuel man, is that to much to ask? lol, j/k. im about to port and polish the head and possibly put larger valves if that is possible, at least a mechanic friend of mine said it was possible, I was gonna check into it more first but you know how that goes. plus i thought the more air/fuel mixture you have you get more horsepower, correct me if im wrong.
you may want to try apexi SAFC. it tricks the ECU to think that there is more air comming in and it will leave the injectors open a little longer and earlier.
As long as by chip you don't mean one of those resistors you plud into the intake temp sensor you should be fine
what exactly are those things and what do they do? ive seen them on ebay for like $20. are those crap? here is a link of one:Originally Posted by 1988starter
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2455019589
i think this is a rip off, or is it?
The stock Injectors are 235cc ACCEL makes one for our cars it's 255cc here is a link to itACCEL Injectors
Originally Posted by 86LXItooFAST4me
It is a 10 cent 3.3K resistor plugged into the IAC it is soposto advance the timing but I find it removed power on my setup
