Results 1 to 18 of 18
Thread: 87 LX-i wont start...need help
    Jan 2004
    I tried to start my car today and all it would do when I turned the key is just light up all the idiot lights...I put a new battery in two weeks ago and I also drove the car on Wednesday...It won't even click when I turn the key to the start position.
    Banned cruznz's Avatar
    Jun 2002
    86 2.0Si JDM DOHC Accord
    have you tried another battery or jump start?
    Jan 2004
    Quote Originally Posted by cruznz
    Nah, it was too cold this morning to be outside...I just hopped in the '03 Mazda this morning instead. I will try it tomorrow...if it does start then I suspect the alternator is bad.
    LXi User soljaboy2000's Avatar
    Jan 2004
    1989 Honda Accord LX
    Hawaii
    Make sure the batt conections are clean too...no corrision etc.
    My 1989 LX Carb. A.K.A. "Hoop Ride" (R.I.P.)
    Sep 2003
    1990 Honda Civic Hatch
    Tulsa, Oklahoma
    Heh funny you mention that I am having same problems and its my alternator. I am getting a new one plus new belts put on. Check your alternator it isnt charging your battery enough I bet like mine.
    Now a Civic Hatchback but was an 87 LX Accord
    Dec 2003
    Millington, TN
    Starer silenoid
    Sound like the starter, if it just clicks either your not getting enough juice (check your voltage in the battery)
    If there is enough cranking amps then I would suspect the starter silenoid
    But make sure your connections are clean from any corrosion.
    Hope this helps, LOL
    NSWST8
    Blkblurr's Avatar
    Jan 2004
    Dayton, Ohio
    Try this simple test.At night, turn your headlights on then try to start your car. If the head lights go out almost completely, your battery does not have enough charge. most likely your alt or bad battery connection. If your lights don't dim then it may be your starter solenoid or ignition switch. Could also be a bad starter motor.
    Jan 2004
    Ok, I was able to start the car by getting a jump off my truck battery. This morning I went out to see if would start and it appears that the battery is dead. Nothing electrical comes on when the key is turned...not even the idiot lights. I have not driven the car since last wednesday. The battery is a brand new battery. Any ideas?
    Nov 2003
    89 Accord LX-i
    Space Coast Florida
    I would look at the battery clamps, sounds like you have a bad connection, if they are loose, and cannot be tightened any further, it's time to replace them with new battery cables..these clamps corrode from the inside out, and is a common electrical problem on our Honda's.
    My other Honda has 2 more cylinders, and 2 less wheels.
    Blkblurr's Avatar
    Jan 2004
    Dayton, Ohio
    Have you checked your alternator to see if it's working. I agree with Tinboat on the battery clamps. If they are not the problem you may have a bad alt or a loose belt on your alt.
    Dec 2003
    Millington, TN
    Follow "TINBOATS" advice
    He's the man. If it is a new battery and you had to jump it then its not receiving a full charge or you have a parasitic draw, somthing is draining your battery.
    Hope this helps
    Phil
    10/Honda/Ridgeline
    NJ
    I remember not to long ago another member had the same issue and i went thru the same issue. Any loose or unhooked ground will draw your battery on the run cuz that open circut is not putting back the power its drawing from the battery. Even tho ur car is being recharged by the alt on the go, its just not enough. I had the problem of the battery dying due to a bad antenna ground. It was weird.
    If you have a multimetter or even an access to one, get it and see if you are putting around 13.5 to 14 volts under no load and something near 13Volts on full load with fan on full, headlights with hazards, interior light and radio.
    If u dont have an access to a meter, start the car up and just unhook the negative cable on the battery and see if the car would die. IF it does, you automatically know its the alt. If it does not, then u got a open circuit on the car that is hindering the battery recharge.
    Put a test light inline to the postive or negative cable of the battery to the battery terminal and shut everything off including the trunk light and interior light and anything that might be on. If it glows, its a visual indication that something is drawing power.
    the next hurdle is to get the shop manual and loook for every ground location and cross referencing them to the ones on ur car to make sure they are intact. Its a long process, but will save a shit load of aggravation if this is gonna prolong.
    Aug 2003
    1987 Accord LXI, 1988 Accord LXI
    Post Falls, Idaho
    You can bask in the wonderfulness that if you do have to replace your alternator, you have an LX->I<.
    Not Carbed. you can just pull the air cleaner off the efi setup and pull the alt out there between the EFI and firewall. 30 min in and out. SO NICE! I feel sorry for Carbed cars.
    I still have a serious power drain issue but thats cause one night i jumped my car with a dead battery and shorted some wiring. Wipers dont shut off and I have to pull the fuse. Wierd. Serious power drain. But thats what parts cars are for!
    Blkblurr's Avatar
    Jan 2004
    Dayton, Ohio
    Let me try to clear up a few misconceptions about grounds and charging batterys. If you are getting 13.5 volts to your battery then your battery will charge. If the battery has an internal short, it will drain all by itself even if it is unhooked. You will need to replace it if that happens. You can have as many loose grounds as you want and it will not cause the battery to drain. Things will not work but in order for the battery to drain,current must flow from the negative back to the positive of the battery. Now iin order to charge a good battery, you need to have a voltage higher than the battery itself. 12 volt battery and a 13.5 volt alt. you now have a 1.5 volt difference so that current can flow. How much current flows depends on how good your battery cable is and whether or not your alt belt is tight. The length of time you run your car will determine how much of a charge your battery gets. Once your battery has been drained you should charge it with a battery charger over night so that your battery gets a maximum charge. I don't want to step on anyones toes but this stuff is what I do for a living. I am an electrical engineer and build systems that test automotive electrical systems as well as many other car components I hope this helps a little.
    Nov 2003
    89 Accord LX-i
    Space Coast Florida
    Great post Blkblurr !!!
    Jan 2004
    Because I am lazy and mainly, I don't feel like f**king with it, I am taking it to this Honda guru who lives way out in the country and all he works on is Hondas and Acuras. He has done some work for me before. He did a head gasket for three hundred bucks. He works cheap and knows his shit.
    check out the defroster circut,it could drain battery down
    Sep 2003
    Tulsa, Oklahoma
    I am thinking alternator because that what it sounds like. Mine was doing the exact same thing not to long ago and the same problems. Oh well we will see what it really is soon enough.
  1. exi wont start
    By beran24 in forum EFI Tech
    Last Post: 11-26-2009, 05:27 AM
  2. 86 accord start then died then wont start again
    By khmerproduction in forum 3geez Accords
    Last Post: 02-03-2006, 08:07 AM
  3. Wont start sometimes
    By sfcmikej in forum 3geez Accords
    Last Post: 08-03-2004, 12:24 PM
  4. Car wont start after i wen out of GAS
    By LeXUS_ in forum 3geez Accords
    Last Post: 07-05-2003, 02:48 PM
  5. Car wont start after i wen out of GAS
    By LeXUS_ in forum Classic Honda Community Chat
    Last Post: 07-04-2003, 02:50 PM
