Results 1 to 13 of 13
Thread: For Those Of You Removing Your EGR!
    Jul 2003
    1987-Gen2 Honda Prelude-FF-2.0L-MPFI-4 Cyl-5 Spd-PWR-BLK
    Ottawa
    I have a few PGM-FI A20 heads that dont have the EGR option even available. If someone wantes me to look for more I can do that. There are a few ludes in the junkyards here and NONE of them have EGR valves, tubes or even the casted piece on the side of the intake.
    I also have a few extra intakes I can part with too if someone wants to do a swap!
    I'm in Ottawa Ontario in case anyone is wondering!
    Drive fast and learn fast to drive slow....drive slow and learn slow....that you can drive fast!!!
    Oct 2003
    B20A SEi
    Oregon City, Oregon
    I wonder if the ECU's from those cars would work well in a USDM model (after removing the EGR).
    shepherd79's Avatar
    Falling Waters, WV USA
    hey man, i am looking black box and ECU from A20A4 with manual tranny.
    it is EFI engine, with no emission crap.
    Justin86's Avatar
    Medford, Oregon
    Quote Originally Posted by shepherd79
    What?
    Well I removed all my emission crap and all I have is the MAP sensor.
    So there is the canadian version lude that dosen't have the EGR option. I'am I reading this right; well that should work, they are both A20 but it won't pass emissions here in the US.
    Sabz5150's Avatar
    1989 Accord SE-i coupe
    Richmond, VA
    Yes, definitely track down the ECUs for the non EGR A20 PGMFI.
    glorious!
    shepherd79's Avatar
    there was a version on A20A4 engine with no EGR. it only had 4 vacuum lines.
    i think Paul from Russia used to have that setup.
    if you look at his manual on page 9-something, you will find intake manifold with no EGR. and if you look farther you will find vacuum setup, and it only has 4 lines for manual tranny. Auto tranny had 5 vacuum lines for non emission version.
    May 2003
    hey boot see any carbed ludes? im looking for a 86-87 carbed intake mani. threre is liek no vac lines on those compared to the usdm ones. if its not to much if u coudl check for me that woudl be great, also the vac control box and the engien computer.
    Justin86's Avatar
    Medford, Oregon
    Damn thats sweet, but would it pass emission here in the US? I might want to get one of those ECU's.
    SEi User
    south dakota
    You guys want to know the easiest way to do this? Take the egr gasket that goes between the tube and the intake manifold, trace it onto a piece of sheetmetal, cut out the shape without the hole, and install it in place of the gasket with some silicone. This is how I did it on my car back when I had the egr tube. (Now I don't have the tube at all, because of my turbosytem) This way the computer won't show any error codes, or trigger the failsafe mode (1500 rpm idle). By the way, I don't think it was worth doing, I couldn't even tell any difference...
    89 LXI
    Maryland
    You mean where the tube connects to the EGR unit or where the unit connects to the intake manifold???
    Justin86's Avatar
    Medford, Oregon
    He is talking about the pipe not the valve.
    bobafett's Avatar
    Stock 86 Accord LXi Hatch
    Longview, WA
    heheh i wanna swap to that setup!
    carotman's Avatar
    Montreal South Shore
    None of the B20A/A20A engines have a EGR hole ON the head. It's all on the intake manifold....
    I need these parts!
  1. Removing A/C
    By conozo in forum 3geez Accords
    Last Post: 04-03-2008, 06:32 AM
  2. Removing A/C
    By kicker1_solo in forum Performance
    Last Post: 10-27-2003, 08:48 AM
  3. help with removing AC
    Last Post: 08-27-2002, 09:02 AM
  4. Removing AC
    Last Post: 08-26-2002, 04:13 PM
  5. Removing A.C
    Last Post: 06-21-2002, 03:05 PM
