Results 1 to 14 of 14
Thread: Could This Be Reason For Concern?
    LX User it's paid for's Avatar
    Sep 2003
    '83 Accord and yeah, I know it's a 2G okay?
    AL border in GA
    I removed my EGR thingy and sort of capped it off . . . best I could, anyway . . . could this in any way affect the engine performance? BTW - I just went to a Weber carb and put on a rebuilt head.
    Thanks,
    IPF
    Ummm . . . brella, I needanumbrella.
    PhydeauX's Avatar
    Eastern Penna
    As long as it doesn't leak its fine. Spray some carb cleaner at it, if the rpms change then it's got a leak.
    andy
    NXRacer's Avatar
    86 LXi Hatch
    Tri-Cities, WA
    as long as it doesnt leak and you dont have DEQ checks. But i guess if you have a webber carb you're not worrying about that anyway........
    hows it running IPF?
    Nothin' 2 Old Racing
    k-roy's Avatar
    87 LX
    Just make sure your cooling system is up to par
    Sep 2003
    AL border in GA
    Thanks!
    BTW - yesterday I almost crashed while driving - I was looking at a new Civic Si . . . geeze, I just think those are fabulous cars . . .
    CLICK HERE TO VISIT HONDA'S CIVIC Si HOME PAGE
    2.0Si User lightbulblxi's Avatar
    Aug 2003
    88 accord lx-i coupe 5sp.
    pulaski wisconsin
    the civics are okay, they look to rounded tho
    -Brian
    My Accord
    Sep 2003
    88 LX auto
    Louisville, KY
    Were you able to tune this car to run decent? It's kind of interesting how much stuff you went through with this project and how much you've learnedand. I hope it has a happy end.
    I intend to live forever - so far, so good.
    Sep 2003
    AL border in GA
    Quote Originally Posted by dysiu
    Okay - the car will run . . . I put about 20 miles on it last Saturday . . . usually, to start the car it goes something like this:
    • Get in the car
    • Smile coz you're in your favorite most bootiful car in the wurld
    • turn the key
    • hear the car struggling to start - sort of sputtering
    • floor the accellerator
    • engine chuggs
    • combustion finally starts but engine is really slow even though accellerator pedal stays floored
    • engine slowly, slowly, slowly gains rpms
    • engine finally revs up and sounds good
    • car won't idle worth crap
    • either the carb must be set to idle "high" or you have to keep feathering the accelerator pedal
    . . . so . . . that's where I am . . . but . . . IT RUNS!!!
    I think if I can somehow just set the valve timing right then re-check the ignition timing it'll be a whole new car . . .
    . . . at least . . . that's what I'm hoping.
    Happy Honda-ing,
    IPF
    k-roy's Avatar
    87 LX
    I think you should just bite the bullet and take the car to a tuner to have the carb jetted correctly. They can also set the timing correctly. Its a slow, tedious process of trial and error.
    *Sticks finger down throat*
    High center of gravity, overweight, MacPherson struts, not as fast as one would think. All that for a little under $20k. Sorry, I'll pass.
    Sep 2003
    AL border in GA
    Great suggestion . . . I'll go this route if I can't fix it Saturday . . . but . . . finding a real, qualified mechanic where I live might be difficult . . . there's my next door neighbor - he's a mechanic and a really nice guy - I'll give it to him! Why didn't I think of that sooner?
    Thanks,
    IPF
    1988starter
    Guest
    Good luck. So besides the rough idle how do youlike the webber was it a nice power increase for you
    Sep 2003
    AL border in GA
    Quote Originally Posted by 1988starter
    The car is running on about half power - builds power slowly and very hard to start & won't idle . . . so, I think the valve timing is off, which is what I'm going to investigate today (Saturday) and hopefully fix . . .
    Mike's89AccordLX's Avatar
    Mankato, Minnesota
    MAn it really sounds like a vacuum leak. Spray some carb cleaner over every vac. line that you have to find it easier (while car is running) and then you will hear the rpms change if there's a leak.
    you problem is vacuum leak somewhere. i mean major leak.
    check around the intake manifold. if you see anything that is not pluged, plug it.
    if that doesn't fix it, you really f**ked the timing
  1. Speedometer concern
    By nswst8 in forum EFI Tech
    Last Post: 05-22-2009, 05:03 PM
  2. Little concern with transmission
    By New3rdGenOwner in forum 3geez Accords
    Last Post: 03-12-2008, 01:32 PM
  3. Not a big concern, just wondering
    By accord newbie in forum EFI Tech
    Last Post: 05-13-2005, 07:20 AM
  4. Lowering Concern
    By 1989se-i in forum Suspension/Wheels/Tires/Brakes
    Last Post: 09-12-2002, 09:40 PM
