I have a 88 DX sedan.
I pulled the knuckle, spindle, hub, rotor, calipers, and e-brake cable. Also the proportioning valve off a SEi.
I plan to go back and pull off the driver side rear disc and master cylinder on saturday b/c of work on friday.
My question is, what else do I need?
Do I need the brake lines for the rear or will my DX brake lines work?
I've read past threads, and some people said to use them. While, some people that ACTUALLY did the swap, didn't mention anything about using the SEi brake lines. I just don't want to buy it if I don't need it. Its about $16 each side.
Are the e-brake cables different lengths b/n a coupe and sedan? The SEi at the yard is a coupe, and I have a sedan. Would I be able to make it fit?
The master cylinder at the yard is missing the cap. Does the cap from my DX master cylinder fit the SEi master cylinder? Or should I just find an LXi with a complete master cylinder instead? Is there any difference b/n the DX/LX and LXi/SEi master cylinder?
Also, the long bolt, the one about 7-8" long on the driver side is stuck. Its the one behind the hub that goes diagonal. I've stepped on it with my weight. I've sprayed it with PB Blaster and after almost an hour working on it, I couldn't get it to budge and eventually called it a day. Any tips for loosening it? I plan to bring a friend with me, and using a pipe on our socket wrench for extra torque. Any other ideas? No, we don't have access to power tools.
Would I have a problem if I ran DX rotors up front instead of the LXi/SEi rotors? One person wrote in a previous thread the stopping power was fine, and didn't mention any problems when he did rear disc swap on his DX and keeping the front stock. For the whole brake assembly for one side, it will run me about $90, and pretty much being laid off last week, I'm trying to cut down on the unnecessary expenses.
Any tips on taking off the brake rotor? Those 2 little 6mm phillips screws are on pretty tight. I've sprayed them with PB Blaster. Is it better to go out and buy a big phillips screws that fits in it snug, or an impact screwdriver? How does the impact screwdriver work? I need to buy extra bits that fits the screw? Or should I just take it to a brake shop and have them take it off for me?
Any help before Saturday morning appreciated, and any help after Saturday, would just mean an additional trip to the yard to get the parts.
