Is it ok to upgrade just the front disc brakes to the bigger 88-89 lxi/sei disc brakes for now or will the braking % be out of whack and you have to do all four disc brakes at once? Also, where is the rear brake proportioning valve located so I can replace it? Also, is a new master cylinder from the 88-89 lxi/sei necessary also? The "how-to" is not very specific and all it does is basically show you what you need. Some good detailed answers would be much appreciated. Thanks guys.
