started thinking about it . . . vacuum leak suggestion (another thread) . . . while the car was running I sprayed the capped EGR manifold with WD-40 . . . but nothing happened - no change in engine speed - thus, I was convinced there was no leak there . . .
. . . then . . . I thought, maybe the cheap, home-made "cap" I put on the EGR manifold was leaking . . . so . . . I took it off, removed the "cap" I made for it (thin aluminum) and cleaned it with brake cleaner & scrubbed it well (in an effort to make this stuff stick) and then put in the "epoxy weld" stuff I got at the auto parts store . . . the plug worked . . . I started the engine and it ran like a new one . . . purrs . . . no chug-chug . . . no wandering idle speed . . .
. . . this is fantastic . . .
I have only one thing to say:
THANKS EVERYONE!!!!!
. . . more later ...
