Results 1 to 9 of 9
Thread: B20A info Again...
    Feb 2004
    Toronto
    Unhappy B20A info Again...
    Hey guys, i searched the FAQ but didn't see anything...but what i did see, mixed me up. lemme know if i got this correct
    from what i gathered,
    2 versions of the JDM B20A...
    -160hp and 140ft.lbs torque (Accord/Vigor?)
    -143hp and 126ft.lbs torque (Prelude?)
    both are 2 liter DOHC motors but how such a differance on numbers with the accord/Vigor motor?? different cams, intake, exhaust manifold between the two? anyone got any dyno numbers on the 160hp version?
    Also, what is the redline and compression ratio on the JDM B20A Accord motor?
    thanks!
    shepherd79's Avatar
    Falling Waters, WV USA
    you are wrong about where each engine goes.
    JDM version of Accord/Vigor and Prelude had 160hp motor.
    In Europe, accord and Prelude had 143Hp motor.
    i don't know the compressio ratio, but i am sure it is 10:1 or higher. rev limit, i think it is just like A20 motor around 6.5K-6.7K
    Dec 2003
    1987 HONDA ACCORD 1.6 EX
    GREECE
    HI 88 HATCH,
    JDM B20A HAS 160Hp/6000rpm and 140ft.lbs/5000rpm
    EUROPE B20A HAS 137Hp/6000rpm and 125ft.lbs/5000rpm
    THEY HAVE DIFFERENT CAMS-ECU-COMPRESSION RATIO
    AUTOCAR ( BRITISH CAR MAGAZINE), ISSUE 4 APRIL 1987 ,HAS A TEST OF THE DOHC
    HONDA ACCORD 2.0i-16..........0-60mph ON 8.2sec, 0-100mph ON 25sec, MAX SPEED:
    125mph, 1/4 mile ON 16.8sec/84mph.( EYROPE SPECS DOHC ACCORD WEIGHT IS
    1185Kg WITH FULL EXTRA ( CROISE CONTROL-SUN ROOF-ALL ELECTRICALS-STEREO-
    ALB), SO WEIGHT/Hp RATIO ABOUT 8.6..)
    SI IF YOU FIND ONE Jdm B20A (IN GOOD CONDISION) YOU'll BE REALY VERY FAST...........
    EYROPE B20A WITH CATALYTIC CONVERTER HAS ONLY 134Hp ( GERMANY-FRANCE
    SPECS VERSION )
    ACCORD 3G RUNS FOR EVER
    carotman's Avatar
    Montreal South Shore
    When refering to the Prelude model, it can be realllly easy to misunderstand things.
    The 2nd gen prelude and 3rd gen prelude both had B20As but they are completely different from the outside.... but they share the same internals (or close to)
    I need these parts!
    SEi User PortugalFocus's Avatar
    Sep 2003
    '13 Civic Si 4dr / 05 Saturn VUE 2.2L 5-Spd
    Clearwater, FL
    So what everyone here is saying is tha the Acura Vigor had the B20A in it? the B20A that is saught after here for the common swap?
    shepherd79's Avatar
    JDM 1 gen Vigor looked just like 3g accord. it had B20A motor.
    10/Honda/Ridgeline
    NJ
    if you want a dyno chart of a stock B20A visit pauls website.
    You want a member's dynochart, ask Foobari or search for his newer posts. He is in Europe and hence has a B20A.
    Feb 2004
    Toronto
    thanx for the info guys! hmmm...whats the addy for pauls site? im figuring stock numbers should be about 135-140whp and 125-130ish torque to the wheels?
    i sourced a couple b20a's here going for $400-500cdn for motor and $300cdn for 5 speed tranny. ecu i had no luck finding yet. I hope to get this swap done asap then start on the suspension. i will keep u guys posted!
    10/Honda/Ridgeline
    NJ
  1. Some useful B20a Info
    By bullard123 in forum JDM B18A / B20A Swap Tech
    Last Post: 02-27-2007, 10:03 PM
  2. info on b20a
    By reanimator420 in forum Classic Honda Community Chat
    Last Post: 09-08-2006, 01:14 PM
  3. AUTO b20A TO MANUAL B20A...ECU InFO
    By AccordB20A in forum JDM B18A / B20A Swap Tech
    Last Post: 05-19-2006, 02:57 PM
  4. So.... B20A info?
    By Doward in forum 3geez Accords
    Last Post: 11-24-2004, 03:22 PM
  5. a little bit o b20a info
    By 88LXI in forum General Engine Swaps
    Last Post: 01-29-2003, 09:02 PM
