Results 1 to 23 of 23
Thread: my tail lights and brake lights went out!! need quick help!! already got pulled over!
    LXi User Dennis's Avatar
    Dec 2003
    88 Honda Accord LX, 96 Kia Sephia RS
    Kentucky
    i already got pulled over for this. everytime i put a fuse in for my tail lights (fuse spot 14 and 15 i believe) it blows the 15 fuse making my tail lights go out. i put a 30 amp in there and it made something under my dash smoke, smelt electrical. Anyways now i don't have any brake lights or tail lights and i need them. i put another 15 amp fuse in the 15 spot yesterday and it worked for a minute (the tails worked) but the brake lights didn't and then it blew the fuse again. I have my amp grounded to my trunk latch could that affect it? thanks for your help
    Dec 2003
    Kentucky
    help please
    shepherd79's Avatar
    Falling Waters, WV USA
    you have some major short somewhere. sorry i don't think you will find help here.
    you have to tear everything out and replace the wirring to fix this problem.
    Dec 2003
    Kentucky
    so i'm screwed?
    Vinny's Avatar
    Aug 2003
    Here, not there
    Dennis, I'll look at my electrical service manual and see what I can figure out as far as cutting the circuit down to troubleshoot it a lil quicker. DO NOT EVER PUT A LARGER FUSE IN THAT THE RATED FUSE. They are there for a reason. If you smoked something my bet is you may have smoked the control box under the radio, you'r brake light circuit runs through there. The earliest I can help you will be Monday, I know thats not alot of help but its the best I can do. Do you have a multimemter? You're going to need one. Did the fuses start blowing right after you hooked up your amp ground? What other things had you done just prior to the brake lights not working. That may help narrow down where things have gone bad
    Dec 2003
    Millington, TN
    Check out the tails lamps first
    Pull your bulbs, check them out are the sockets corroded or have any type of residue on them. alot of the time when I come accross tail lights its due to water infiltration.
    Then if this checks out start to trace the wires back through the harness to the dash, you are looking for anything frayed, bent, crimped, crushed, wet. Anything that doesn't resemble a good clean wire.
    Also think back did you do any mods that may be responsible. A friend of mine always reminds me that its always something stupid.
    Don't ever think that its never that simple, you'd be surprised.
    Hope this helps, LOL.
    Phil
    Dec 2003
    Kentucky
    my tail lights went out first but my brake lights still worked. as far as i know the brake lights stopped working after i put the bigger fuse in the fuse spot 14 or 15 (not sure which one since i've been messing with them both) the only thing i did was hook up the amp, nothing else. is there anyway i could bypass the fuse box for now so i can temporarily have brake lights? the tail lights arent so important since i drive mostly in the day but i really need the brake lights.
    Nov 2003
    89 Accord LX-i
    Space Coast Florida
    Sounds like your amp is hooked up wrong...does it work ? Where did you get your power source for the amp?...check for unplugged wires ie: ground wires, and make sure you didnt run a screw through a harness....
    Good Luck !!!
    My other Honda has 2 more cylinders, and 2 less wheels.
    Dec 2003
    Kentucky
    the amp works, i get power from my battery and it's grounded to the trunk latch. it used to be grounded to a bolt right next to the tail lights. the amp works fine but my lights are the problem. i haven't screwed anything into my car to have broken any connections or anything.
    Dec 2003
    Millington, TN
    Bypassing the fuse will only fry the harness.
    You already smoked the brake light wires from what it sounds like, bypassing will only make things worse. You must follow the wires.
    Under the hood relay box calls for 30A fuse @ the #3 position (GRN) Brake lights, #4 position calls for 20A fuse (WHT/YEL) Brake lights
    I don't see anything related to under dash fuse box except the brake warning light in the dash
    #14 fuse 15A (RED/BLK) taillights, vanity mirror, license plate, rear side markers, dashlight bright control unit, etc
    #13 fuse 10A (YEL/RED) pwr antenna motor radio/cassette player
    Phil
    LX User chriskatana's Avatar
    Jul 2003
    1989 CRX DX 1989 CRX Si 1990 CRX DX 1994 Toyota 4Runner
    Tuscaloosa, AL
    had the same problem with mine when I first got it, the radio had been ripped out and the wires were touching the dash frame shorting it out.. check your radio intall and wires.
    LXi User soljaboy2000's Avatar
    Jan 2004
    1989 Honda Accord LX
    Hawaii
    yeah, check the bulbs for corrosion my bulbs went out because of it before.
    My 1989 LX Carb. A.K.A. "Hoop Ride" (R.I.P.)
    Blkblurr's Avatar
    Jan 2004
    Dayton, Ohio
    You have nearly a dead short in your tail light circuit. I would look for pinched or bare wires touching the frame of the car. It has to be a positive wire touching a common (frame ground). Otherwise it wouldn't blow a fuse. Don't put larger fuses in because the wires burn if they are the weakest link. If you put a 30 amp fuse in and the wire was designed to handle 15 to 20 amps. the wire will melt. I would inspect the fuse box for damage or loose wires that may be touching other circuits. Look for melt damage. If you find melted insulation on wires under your dash coming from the fuse box the short is not in the fuse box but in the wires leading to the light sockets. Next I would remove the sockets and or wires from the tail lights. Isolate them from the car frame ground. If no short after putting a 15 amp fuse back in then put the wires back on the sockets one at a time until the fuse blows again. You've found the problem at that point. This is the proceedure I use when tracking down wiring problems but I also use a voltmeter.
    Hope this helps
    Dec 2003
    Millington, TN
    Hey, Blkblurr
    Welcome to the site, just checked out your refs. Thanks for helping us floundering members.
    I'll be sure to read your posts as I see them.
    Phil
    Blkblurr's Avatar
    Jan 2004
    Dayton, Ohio
    Thanks Phil Glad to help
    Jim
    Dec 2003
    Kentucky
    tail lights still fucked, i fixed the brake lights (the fuse was taken out by someone )
    Dec 2003
    Millington, TN
    Half way there.
    You see, like I said before something "Stupid"
    We'll help you with that half too.
    Phil
    Dec 2003
    Kentucky
    Quote Originally Posted by Dennis
    I wonder where I got that 30a fuse from?? Since my horn doesn't work I took the horns fuse, well just my luck the horn and brake lights run off of the same fuse. Thats why my brake lights didn't work.
    Dec 2003
    Millington, TN
    Its all too familar.
    You will never know how many times I've had that same feeling.
    Stupid , Stupid , Stupid , Stupid
    But hey, thats what were all here for.
    Glad we could help,
    Phil
    Dec 2003
    Kentucky
    ok i have fixed the problem. for some reason my cd player, when i pulled it out went up in smoke... but anyways, after i pulled it out, i looked into the dash and seen that the wires going to the dash light and to the cigarette lighter had the pigtail melted on it really bad. well i cut that off and now my tail lights work. thanks for all your help
    Dec 2003
    Millington, TN
    Easy Day.
    Again its always something "stupid", But just alittle time and patience and anything is solvable.
    Glad your good to go.
    Phil
    Blkblurr's Avatar
    Jan 2004
    Dayton, Ohio
    Good work man. Feels good when you find the prob.
    LXi User Magny's Avatar
    Aug 2003
    1987 Honda Accord LX
    Cali Baby
    LOL damn dude, welcome to the club. Same damn thing happened to me too. but I solved it quick considering the last thing i did before my fuse popped was the radio wire touching the frame.
  1. Replies: 0
    Last Post: 12-10-2011, 09:42 AM
  2. tinted trunk lights w/ clear/red tail lights
  3. anyones brake lights also turn on your dash lights?
    Last Post: 03-07-2004, 01:31 AM
  4. my tail and brake lights
    By mig88lxi in forum 3geez Accords
    Last Post: 11-06-2002, 07:50 AM
