Alright folks, this has probably come up before, but I'm having a problem with my car when it's warm/hot.
When warm, it has a tendency to sometimes idle low, around 800-900 RPM. I expect this kind of behaviour from a rumpity-cam SB Olds, but not my 88 LX-i. The other thing is, when warm, the engine will crank and crank and crank, but not start. After a while of cranking on it, you can smell fuel, almost as if it were flooded.
The guy I bought it from said it happened fairly often to him, but this is the first time it's happened to me. I want this fixed. Is it the ECT? I know I will have to check the ECU codes to be damn sure, but I am asking if this sounds like a bad ECT.
Forgot to mention that a search turned up a couple references to the ECT and odd idling, but nothing about it preventing the engine from starting.
Ben/Radu
