K I won't get into how but my 5speed is now a one speed
I have access to a few first gen Tegs and a few 2nd gen ludes as well as a few accords. So what I'm asking is what do y'all think I should go with ?
Teg.......
So will the 1st gen teg trans bolt right up?
Your going to swap the gears to an Accord housing and then bolt it in. Now the Ludes bolts right up but you have to use a lude clutch and possibly flywheel too.
I believe there is a "HOW TO" on this.
Hope this helps, LOL
Phil
Thanks alot It does help! It seems to me that the lude trans has a bit of gear ratio advantage....correct me if i'm wrong
So I did so searching and If I got this right I CAN bolt up a teg transmission if I use the accord bellhousing Anybody confirm this?
and ps Do the axles slide right in to the teg diff?
