Results 1 to 6 of 6
Thread: Injectors
    Nov 2003
    1988 Honda Accord 2 door Coupe
    Panama City Florida
    Injectors
    I noticed that one of my injectors is leaking between where the metal meets the plastic electrical connector. I need to know what might have caused this because i am clueless. I am going to pull some new injectors from from the junkyard down the road next weekend. i am getting them out of a lude. are they the same CC as a 3g 1988 honda accord?
    Dec 2003
    Millington, TN
    Could just be the O ring
    If you were in that area and knock it by accident, its possible to have cause an old O ring to crack.
    Hope this helps, LOL
    Phil
    LXi User johnwc723's Avatar
    Feb 2003
    89 LX-i 5 speed
    Madison, WI
    yeah dude mine had the same problem, its a big issue for our cars, the leak between the "metal and the plastic" i just got remanufactured ones, one of them started to leak even so i bought one from a friend
    Check out pictures of my car HERE
    "drop a 150 shot of NOS sticker on that bad boy and you can run 8s" -portugalfocus
    Blkblurr's Avatar
    Jan 2004
    Dayton, Ohio
    It happens to all to them due to age and the fact that the fuel is under pressure. It will find it's way out through small cracks or worn seals. You cannot repair these but they alll will leak eventually.
    Feb 2003
    89 LX-i 5 speed
    Madison, WI
    yep, gasoline is a solvent too hehe, yeah i tried to repair mine wiht epoxy and it sure didnt work, best bet is to replace the effected injector
    for some reason whenever someone brings up this problem people always think ohh it must be the O-ring! in your case it isnt, havent acutally seen an oring issue yet..
    Blkblurr's Avatar
    Jan 2004
    Dayton, Ohio
    It's actually a press fit with a thin gasket between the plastic body and the stainless injector housing. The company I work for built some equipment that assembled them years ago. The honda engine plant is 40 miles from my house. Your not likely to see an o-ring problem unless it's the one in the fuel rail to injector. That one is trapped pretty good. The ones going into the intake manifold are not under pressure anymore so they shouldn't leak.
  1. 4th gen injectors
    By import racer in forum EFI Tech
    Last Post: 12-09-2011, 01:52 PM
  2. injectors and an FMU
    By newaccorddriver in forum Forced Induction
    Last Post: 06-27-2006, 06:08 PM
  3. injectors
    By gp02a0083 in forum EFI Tech
    Last Post: 12-30-2005, 11:40 AM
  4. DSM Injectors
    By 1988starter in forum Performance
    Last Post: 02-10-2004, 05:56 AM
  5. 88 injectors on 86???
    By od2681 in forum 3geez Accords
    Last Post: 07-23-2003, 04:39 AM
