Results 1 to 16 of 16
Thread: Rear drum brakes !
    Oct 2001
    87 Accord EX , 5spd , Manual
    Angry Rear drum brakes !
    hello everybody ! it's really not a good week for me ! ( read in the off topic section ! )
    anyway , when replacing rear drum brakes do i need to take the hub off , if not , how do i get the shoes out ??
    MIKE
    just take off the rear wheels and make sure the parking brake is not engaged (block the front wheels!! ) the drum should slide right off, no need to get a hub puller or anything
    Eric
    Oct 2001
    i did that !! but how do i get the assemble out ! it says in the haynes to remove the 32 mm nut and remove the hub them remove the assembly ???
    MIKE
    dj99's Avatar
    88 LX 5-speed Sedan
    Southwest WA
    I read that in Haynes too. Ignore it. You can replace the pads without taking the hub off. You can jimmy all the parts out of there without too much trouble.
    Nov 2000
    While it might be easier to replace the shoes with the hub off, you DO NOT NEED TO REMOVE IT. The honda shop manual indicates that you can slide the whole shoe assembly down after removing the pins and springs that go through the shoes to the brake backing plate.
    I have changed mine three times in the life of the car and have never removed the hub.
    Oct 2001
    thnx guys ! i did it today ! but it doesn't really stop the car ! and the hand makes 7 clicks !???? how do i tighten it ! ?
    thnx
    MIKE
    dj99's Avatar
    88 LX 5-speed Sedan
    Southwest WA
    It should be 7-11 clicks. You're done!
    Oct 2001
    but it doesn't really lock up ! ?
    MIKE
    dj99's Avatar
    88 LX 5-speed Sedan
    Southwest WA
    Were your adjusters seized up? Did you adjust them almost too tight to put the drum on and then back them in a bit? You can also adjust them manually from the back. Did you do one brake at a time and not mix up the two adjusters (they are threaded opposite than each other, and if mixed up would never adjust right, I think)? Have you driven in forward and reverse a bunch of times in your driveway or street to automatically adjust them?
    That's all I can think of offhand. I hope I helped more than confused!
    when adjusting the drum pads i like to set it as far as possible until i feel the pad make contact then i back off a turn but i still can't lock up lol
    Eric
    Nov 2000
    I think "Emergency Brake" is really a misnomer for this device. It is more of a "Parking Brake." If you ever have to rely on this alone to stop the car you are hosed. With the two circuit hydraulic system it is very unlikely that your regular brakes will ever fail totally. My original master cylinder went bad while the car was still covered by extended warranty and I drove with half a brake system for about a week so that the dealer would have a loan car available for me. Even then it stopped pretty well.
    I used to adjust mine for fewer clicks and all that did was wear out the shoes faster. If the brake keeps the car from rolling on a decent incline it is doing its job and that's about all you canexpect from it.
    damn, i used to do powerslides in my grandparents' altima, that shit locked up EASY, pisses me off that i can barely stop with my 'emergency' brake
    Eric
    accord HB ( metallic green)
    B.C Chilliwack
    ya its a pain in the ass to replace the pads without removing the hub but if your not replacing all the hardware ( springs,etc.) then it shouldn't be that bad. Good luck
    2.0Si User pimp86LX's Avatar
    2005 Mazda 3
    Ontario Canada eh.
    Meh you don't need the wheels to lock to power slide...heh heh just GIve'ER! start your turn and when you break traction whip that sucka up..it'll work :flipa: :flipa:
    i know that i just want to know if having such little stopping power in the rear is 'normal'
    Eric
    Oct 2001
    i did the adjusting bolt and it locks up just fine !
    i'll post exactly when i get my computer back !
    MIKE
  1. Rear drum brakes install tips?
    By 1989accordaz in forum 3geez Accords
    Last Post: 12-24-2008, 09:56 PM
  2. [Suspension, Wheels, Tires & Brakes] Rear Disk Swap, with pics (for those with drum brakes)
    By OldSchoolSwap in forum How To
    Last Post: 01-26-2007, 02:45 PM
  3. Rear drum brakes help please!
    By md21722 in forum 3geez Accords
    Last Post: 03-15-2005, 11:17 PM
