Results 1 to 16 of 16
Thread: timing retarded 12 degrees
    LXi User johnwc723's Avatar
    Feb 2003
    89 LX-i 5 speed
    Madison, WI
    i just checked my timing today and it appears to be retarded 12 degrees!!! (its at about 3 deg and supposed to be 15 +-2) i was having problems finding the third bolt so i wasnt able to fix it yet (is the last one under the distributor on the a20a4 engine) the manual said it was on top but IT ISNT! hmm
    what kind of performance/ MPG gains do you think i will get when i "un-retard" my timing
    Check out pictures of my car HERE
    "drop a 150 shot of NOS sticker on that bad boy and you can run 8s" -portugalfocus
    Nov 2003
    89 Accord LX-i
    Space Coast Florida
    Once you get it set right, yer gonna notice one hell of a difference !!!...Like about 20% increase in power and fuel economy !!!
    My other Honda has 2 more cylinders, and 2 less wheels.
    Jul 2003
    1987-Gen2 Honda Prelude-FF-2.0L-MPFI-4 Cyl-5 Spd-PWR-BLK
    Ottawa
    if you return your timing to stock you will see smoother engine performance, less fuel consumption and more power on the highway!
    Timing does A LOT. MORE than one would think!
    The distributor has 3 bolts which hold it to the head. These bolts are in a triangle pattern. Some of the A20 engines have the dist upsidedown. Not really...its a diff dist. but it looks upsidedown!
    If you see two bolts on the top there is one on the bottom you are missing. You may need to disconnect one of your coolant hoses to reach it!
    TIP...dont take the bolts out...just make them loose...that way the dist wont fall off in one hand with a timing light in the other!
    ALSO...if you own a prelude like me....you need to remove the hood to check the timing....CAUSE IT OPENS THE WRONG WAY! (stupid thing)
    you cant see the timing hole properly ....
    do this on a hot engine...not a cold engine!
    Good luck!
    Drive fast and learn fast to drive slow....drive slow and learn slow....that you can drive fast!!!
    Nov 2003
    89 Accord LX-i
    Space Coast Florida
    I use a mirror on a telescoping shaft to set timing on the older Preludes...
    Jul 2003
    Ottawa
    Quote Originally Posted by TINBOAT
    how?
    One hand on the dist. the other holding the timing light....then your outta hands!
    Nov 2003
    89 Accord LX-i
    Space Coast Florida
    Just loosten the distributor enough that it will rotate with a fair amount of drag on it, one hand on the mirror, other on the light..advance or retard as needed, then recheck.
    Feb 2003
    89 LX-i 5 speed
    Madison, WI
    cool im really excited about this!! the most effective engine mod in my case looks like it is going to be free!! i hope its not far enough off that i have to mess with the belt though !!!!!
    Jul 2003
    Ottawa
    You should not have to touch the belt. The belt control VALVE timing. The distributor controls IGNITION timing!
    Even though they run off the same cam and if you adjust the valve timing you will adjust your ignition timing....they both control two diff things!
    Feb 2003
    89 LX-i 5 speed
    Madison, WI
    ohh hehe alrighty damn i was looking to buy a timing light and there was a $30 actron one.. the wierd part was that it dosent have any sort of knob on it to turn or anything to specify the timing, it dosetn even mention anything in the manual, it only talks about turning the knob (a different model has a knob but costs $60!!) hmmm
    LXi User Magny's Avatar
    Aug 2003
    1987 Honda Accord LX
    Cali Baby
    I have that actron one and I have it without the knob and still set my timing right. you don't really need it unless you arent sure where your timing is without moving the dis.. that one with the knob just tells you how far advanced or retarded the timing is.
    LX User Volitech's Avatar
    Oct 2003
    91 civic hatchback JDM ZC swap, Yamaha FZ600
    Madison, WI
    For being 12 degrees retarded your car didn't sound like it was running bad at all I'd be interested in seeing it run again after you adjust that!!
    Chrome and paint don't equal speed and horse power!!
    Feb 2003
    89 LX-i 5 speed
    Madison, WI
    yeah, im not sure how the hell those ones that dont have the adjuster are spposed to work! how does the light know what you are timing the engine for?
    Banned cruznz's Avatar
    Jun 2002
    86 2.0Si JDM DOHC Accord
    Quote Originally Posted by johnwc723
    the induction clamp you put on No1 spark plug lead cause's it to flash everytime No1 gets spark from dissy.
    One of the best timing lights I've used is digital, it'll read/check RPM,and vacuum advance at the same time as well,but like all good things, cost a few dollars
    Aug 2003
    Cali Baby
    All it does is tell you how far your timing is off. I found out when I got it smogged that I was 7 Pos. when I did it myself with the one that isn't with the knob, I put it back at TDC. so the one without iso nly of you want to make it at TDC, the one with the knob is to help you determine how far advanced or retarded you want the timing to be.
    Feb 2003
    89 LX-i 5 speed
    Madison, WI
    ohh so we dont want to put our car at tdc anyways, we want it to be advanced, so it dosent really work then eh?
    Aug 2003
    Cali Baby
    yeah, basically. the one with the knob is the best one in my opinion, that way you can get an accurate timing advance or retard with the timing light.
  1. AC 60 degrees
    Last Post: 06-16-2007, 12:34 PM
  2. a/c goes few degrees lower when car slows down
    By AC439 in forum 3geez Accords
    Last Post: 07-02-2004, 04:18 PM
  3. A20A / Changing The Timing is Retarded!
    By BootMachine in forum 3geez Accords
    Last Post: 09-04-2003, 10:14 AM
  4. Replies: 7
    Last Post: 06-02-2003, 06:29 PM
  5. 18 , 20 , 22 degrees ignition timing ?
    Last Post: 05-07-2003, 11:28 PM
