Originally Posted by
Lok
THE TORQUE CURVE OF B16A1 (IF YOU DYNOED) IS FLAT BECAUSE OF VTEC.
THAT MEANS THAT B16A1 HAS A LOT OF TORQUE ON LOW RPM ( MORE THAN
12kg.m/1500rpm) AND A LOT OF TORQUE AT VERY HIGH RPM 14+kg.m AT 8000rpm
( WHEN B20A AND A20A3 HAVE NO TORQUE AT THAT RPM LEVEL , REV LIMIT UNDER 7000rpm).
THE B16A1 AND ALL THE B SERIES ENGINES ARE VERY GOOD FOR OUR CARS IF
YOU WANT TO SPENT A LOT OF MONEY FOR 3G ACCORD, BECAUSE OF THE HUGE
AFTERMARKET SUPORT................................YOU COULD MAKE EASY A B16A1
WITH OVER 400Hp ( TURBO)......
IF YOU WANT JUST TO PUT A PERFOMANCE ENGINE ON YOUR 3G ACCORD, THEN
IS BETER AND CHEAPER ,TO SWAP A B20A ( jdm 160Hp, IF YOU FIND ONE WITH
MANUAL TRANSMISSION, IN GOOD CONDITION???) OR IMPROVE YOUR EFI-CARBED A20.
EK CIVIC SI ( BOTH 3D AND 4D CAME TO EUROPE) WEIGHT MORE THAN 2800lbs
(MORE THAN A 3G ACCORD, BECAUSE OF HUGE SAFETY EQUIPMENT, AIR BAGS ETC)
BUT THEY ARE VERY FAST WITH THE B16A3 ( EYROPEAN SPEC 160Hp ,THE SAME AS jdm B16A1) 7.7sec aceleration 0-62milee, max speed 130+miles/h, 1/4mile ON 16sec..................................
A 3G ACCORD WITH B16A1 WILL BE MUCH FASTER,THAN EK CIVIC SI, BECAUSE WILL LOST WEIGHT FROM B16A1 ( A20 HAS 2.0L CAST IRON BLOCK, MUCH HEAVIER THAN B16 1.6L ALLOY BLOCK) .
