Results 1 to 19 of 19
Thread: bad EGR (Error code 12)
    Feb 2004
    Honda Accord 1987 LXi
    Costa Rica
    Hi,
    I have an Accord LXi 1987. The last week the PGM-FI turned on.
    So, I checked the ECU flash light, and said that is an error code 12.
    I realized that when the light turns on the idle ups to 1250 RPM. But when the light is off, the idle is 750 RPM.
    Is a symthom that th EGR is bad, or is another thing?
    Regards.
    AZmike's Avatar
    Jul 2002
    Tucson, Arizona
    Yes, the EGR coe cuases teh change in idle. When the computer sees that the EGR is not working right the computer goes into fail-safe mode which raises the idle to 1200 rpm. My prelude is doing the same thing. I've heard it's related to the constant vacuum valve in the black emission box.
    Mike
    Feb 2004
    Costa Rica
    thanx
    thanks AZmike.
    So, the next step is the change of the EGR valve.
    AZmike's Avatar
    Jul 2002
    Tucson, Arizona
    The problem probably isn't the EGR valve itself, but the solenoid, constant vacuum valve and vacuum chamber that contol it. They're all found in the emission box. Several people have had similar problems and fixed them. I'll see if I can did up their posts later if you're not able to find them yourself.
    Mike
    1988starter
    Guest
    Why I would do is take off the egr valve and blast it with carb or throttlebody cleaner
    AZmike's Avatar
    Jul 2002
    Tucson, Arizona
    There's a chance that would would help. It didn't make any difference for me though.
    Mike
    1988starter
    Guest
    it fixed the one on my friends tempo
    Jan 2004
    87 Accord lxi 5spd hatchie/84 accord lx 4-dr/74 dodge dart
    Escondido,Ca(San Diego)
    Don't do that!
    Quote Originally Posted by 1988starter
    Dude I did the same thing last week and thought the problem was solved.Then my light came on again.WTF!I have replaced the sensor the valve was still good.
    The problem w/ the spray is that it just sits on top of the valve doing nothing.If the valve is stuck it just sits there and if the valve is opened it will evaporate pretty quickly.Your best bet is to get a new sensor or new EGR all together they are very expensive.About 200.00 bucks in my area.I went to the junkyard today and scored one that appears to be working for about 13 bucks including insurance so that if it doesn't work I can take it back
    I'm a mushroom cloud layin' mutha fu**er,muthafu**er--Samuel L. Jackson in Pulp Fiction http://www.cardomain.com/id/mattalica13
    1987 Accord LXi
    Southern Cal
    Talking
    I had a code 12 for awhile now, and at first, I could unhook the battery to clear it and it would be OK for a few weeks. Then, it got to the point that as soon as the engine was up to operating temp, the pgmfi light would come on. My car had 312K, and the valve seals were gone (smoked heavily on start-up), and I figured that maybe my engine was making so little vacuum that it wasn't lifting the EGR valve. I swapped out the old motor for a JDM long-block with 28K miles. I troubleshot the EGR system using the factory manual (worth EVERY penny!), and it got down to the point to where the CVC valve was the next to change. I wanted to make sure that I wasn't wasting my money on buying a new part from Honda that may or may not be bad, so I went to my local wrecking yard and cut out 2 emissions boxes from an 88 and an 89 Lxi car. I swapped out CVC valves and carb-cleaned and blew out the air chamber with my compressor. I installed the parts, and it runs great. So far, there has been no pgmfi light. I hope this info helps anybody with a code 12 problem. Total cost: 15 bucks.
    So many projects, so little time...........
    55 chevy truck Pro-Street
    71 Z28
    73 Chevy half-ton
    02 Civic EX
    87 Accord (The work-horse)
    May 2004
    1989 honda accord lxi
    va beach
    i need help with my code 12 problem. i have replaced the egr valve 3 times now all junkyard donors, reseted the computer each time i put a new one in, replaced the vaccuum solenoid and some other vaccum shit that i dont know what it was or anything all i did was follow all the vaccum lines that tied into the egr vavle and replaced those components, everything i got was from the junk yard. i think my next step is to just put a egr block on it and call it quits. i would much rather find out what else could be my problem and fix it the right way instead of just elimating it.
    :alc: 1989 honda accord lx-i, msd ss coil, iridium plugs, true cai, ported polished 3 angle valve job, dynomax muffler, hollow cat, dc sports header, eibach lowering springs
    Mar 2006
    Re: Don't do that!
    Quote Originally Posted by mattalica
    where is the egr valve sensorS?????
    'A20A3''s Avatar
    Mar 2003
    '89 LXi Coupe
    eastern shore, MD
    Re: bad EGR (Error code 12)
    I ripped mine off and now I have that 1200 idle. I don't care though.
    If it's not necessary for the engine to run, goodbye.
    -Harvey
    shepherd79's Avatar
    Falling Waters, WV USA
    if you are going to replace the EGR valve with a used one from the junk yard, make sure it can hold the vacuum. A lot of them don't hold the vacuum.
    SEi User wallyyfm's Avatar
    '88 Accord LX (Sold), '94 Buick LeSabre "The Tank", '86 Lxi New Project
    Northern New York
    i just got one from berto as I'm having the same problem...i'm installing today
    Northern New York
    doesn anyone know how hard it is to get the fucker out?
    well, IT'S FUCKING HARD
    i needed a jointed socket to get it out, and i ended up smashing it anyway
    whatever, i replaced it with a EGR that held good vacuum, and nothing, still get the code
    so...i apparently need to open that spider box...and do what exactly?
    Northern New York
    well, i might have it beat, it didn't turn on from my way from work to class, it did on the trip before, RPMs stayed at 900 on idle...i'm hoping it stays off, if not, i'm going to be looking for a EFI box
    LX User Versanick's Avatar
    Jun 2002
    1986 Honda Accord LX Sedan (RIP), 1989 (same) RIP, 86 Hatch Lx-i, JDM b20a, Gude headpkg, AEM cam gears/cai, thermal xhst, 2.5/3" lowrd tokico/groundctrl, 17" Seneca whls, hypereutectic pistons, .020" over, 13:1 comp
    Upstate NY
    just plug the vacuum line (that goes to the EGR) and use your idle adjustment screw to drop your idle down below 1000.
    Northern New York
    well yeah, i could do that, but i would actually like to fix the problem
    it came back on, im going to open the box up this weekend, see what i can do, maybe some boxes down at the yard
    LXi User Nospeed's Avatar
    Oct 2002
    87 busted ass hatch
    Salem, OR
    im getting the same code. the wires for the sensor on the exhaust manifold have been cut by the previous owner, or some crap...would that make my fast idle as well?
    - Justin
  1. I got an ECU ERROR code today... (PGM-FI Light)
    By dosh8er in forum 3geez Accords
    Last Post: 07-21-2008, 11:29 PM
  2. 86 LXi Caliper pin stuck, also 12 blink error code
    By bobbyang1 in forum 3geez Accords
    Last Post: 06-02-2008, 08:02 AM
  3. FAQ's error?
    Last Post: 12-04-2005, 04:01 PM
  4. Error in FAQ??
    By xbi0s in forum Classic Honda Community Chat
    Last Post: 03-21-2003, 11:04 AM
  5. Error 12, Error 12. She's Gonna Blow
    By Immeraufdemhund in forum 3geez Accords
    Last Post: 03-18-2003, 06:03 AM
