WEll according to my chilton manual (cant read the diagram to well)) MY CAR IS SCREWeD!!
My car has a problem with revving up in between shifts,,but this only happens after the car is warm... and i though it might be the throttle controler,,,well for starters im not sure which one it is...on the left facing the carb or the diaphram on the right???The maual isnt clear about this....and the diaphram on the right bottom..by the acceleartor pump thing,,isnt even hooked to a line that would make vacuum but to a closed off one..
Just need to know if my vacuums are all screwed up and if I could be right on the throttle controlleer..or is it my carb in need of a rebuild???
Thanks in advance...I need to fix this before the end of the month...going on a road trip..
Oh also the power boost thing that forces air into the exhaust at high throttle.. the solenoid is stuck open so i disconected it..Will this affect performance at all.????
Ben
