Results 1 to 8 of 8
Thread: Intake question
    Dec 2003
    87 accord lx-I hb
    Oregon
    Intake question
    On a short ram or cold air intake where does the little hose on the intake it self. where does it go?
    um yeah
    Jul 2003
    1987-Gen2 Honda Prelude-FF-2.0L-MPFI-4 Cyl-5 Spd-PWR-BLK
    Ottawa
    to the valve cover. Its part of the PVC system!
    It sucks oil fumes out of the valve cover and burns them in the engine!
    Drive fast and learn fast to drive slow....drive slow and learn slow....that you can drive fast!!!
    SEi User PortugalFocus's Avatar
    Sep 2003
    '13 Civic Si 4dr / 05 Saturn VUE 2.2L 5-Spd
    Clearwater, FL
    it goes to the valve cover........
    Dec 2003
    87 accord lx-I hb
    Oregon
    could you just put a small filter on the valve cover
    um yeah
    1988starter
    Guest
    just hook up the hose so the vacume from the manifold draws the gasses out
    Mike's89AccordLX's Avatar
    Mankato, Minnesota
    Yes you can put a small filter on the valve cover. Then you would need to cap off the intake port then.
    Jul 2003
    Ottawa
    Quote Originally Posted by Mike's89AccordLX
    not worth it.
    The PCV robs you of hardly any power and those little filters fall apart in about 2 years...and they are expensive!
    You engine will run better with it where it should be anyway!
    IMHO....do it right!
    bobafett's Avatar
    Stock 86 Accord LXi Hatch
    Longview, WA
    there are 5 hoses u need to worry about with 86-87 EFI system.
    the first 2 are on the far right side, i used a breather first, attacthed to the small black box, that WAS on the stock airbox. but now i just bought a T, and hooked up both lines all the over to my intake pipe (looks worse lol)
    the big one is what was already mentioned, it goes to your valve cover. and then there are 2 smaller hoses that come from the mystery vaccum box, just drill like a 5/16 and 3/8 hole in your intake and fit the little tubes in.
    btw u dont need to hook up the left side hoses, but car has vaccum issues if u leave the two on the right off..
    my big hose from valve cover to intake pipe falls off all the time, and it doesnt hurt function..
    there u have it man
  1. Air Intake Question
    By nomercy0632 in forum Performance
    Last Post: 09-01-2009, 08:03 PM
  2. Intake question?
    By JFreddy in forum Performance
    Last Post: 10-12-2004, 09:02 AM
  3. intake question
    By hondaaccord_86 in forum Carburetor Tech
    Last Post: 08-10-2004, 10:58 PM
  4. question which intake will fit...
    By Micah 89LXi in forum Performance
    Last Post: 10-29-2003, 10:44 PM
  5. New intake...Now the big question...
    By 89bumblethumper in forum Performance
    Last Post: 08-07-2002, 02:00 AM
