Results 1 to 8 of 8
Thread: Disconnect PGM/FI light
    Jan 2004
    87 Accord lxi 5spd hatchie/84 accord lx 4-dr/74 dodge dart
    Escondido,Ca(San Diego)
    Question Disconnect PGM/FI light
    My question is a 2 parter.How can I disconnect the PGM/FI light?I think I read somewhere that it is the brown wire in the ECU.Is that right?Second will it make my car fail smog?I mean it is the EGR valve code and I have replaced it!Still the light comes on.If it comes on during a smog test I will automatically FAIL.So if the light is disconnected....Imean it is just a sensor not actually an emissions device?Right?Any help will be greatly appreciated.I know I should do it right,but,I only have til friday to fix the problem!Thanks ,Matt
    I'm a mushroom cloud layin' mutha fu**er,muthafu**er--Samuel L. Jackson in Pulp Fiction http://www.cardomain.com/id/mattalica13
    shepherd79's Avatar
    Falling Waters, WV USA
    if you replaced the valve and the light still comes on, you need to replace the EGR control solenoid valve. it is located inside the black box.
    you can open the box and replace it or you can replace the hole box.
    i had the same problem when i got my new car. i changed the EGR valve 3 times, and i finally changed the black box and it fixed the problem.
    did you actually replaced the valve or you just cleaned it?
    if the valve is not working you won't be able to pass the emission test.
    Jan 2004
    What is the black box and where is it located?Do you mean the box where all the vacuum lines go?thanks,Matt
    shepherd79's Avatar
    yeah that is the box.
    86LXItooFAST4me's Avatar
    Dec 2003
    1986 Accord LX-i *** 2002 Mustang GT
    Austin, Texas
    i think its the black box on the passenger side fire wall with all the vacuum lines running to it, i think
    "Seriously, I have a half o' pack of Rolaids in my dipper" -Stewie (Family Guy)
    Car Pics
    vBGarage
    Banned cruznz's Avatar
    Jun 2002
    86 2.0Si JDM DOHC Accord
    I've also found the CSV to be at fault when EGR tested ok, as they tend to get dirt and particals in them making them leak at idle, and the ECU gets a wrong signal from EGR.
    I also think whoever tests it may notice your CEL not come on when you first turn the ignition on
    Jan 2004
    Quote Originally Posted by cruznz
    I've also found the CVC to be at fault when EGR tested ok, as they tend to get dirt and particals in them making them leak at idle, and the ECU gets a wrong signal from EGR.
    WTH is a CVC and a CEL?
    Jun 2002
    CVC is constant vacuum control,......but i meant to put CSV, Control solenoid valve....CEL is check engine light....have edited my last post
  1. Replies: 7
    Last Post: 01-07-2012, 10:19 AM
  2. Auto shifter Cable disconnect (Integra)
    By bushbean in forum 3geez Accords
    Last Post: 06-04-2010, 06:48 AM
  3. Replies: 17
    Last Post: 08-31-2009, 08:51 AM
  4. Can't disconnect stock bose radio
    By nfs480 in forum Interior & Exterior Care
    Last Post: 02-19-2008, 05:40 PM
  5. is it ok to disconnect original clifford alarm?
    By neoblue89lxi in forum 3geez Accords
    Last Post: 07-23-2003, 09:44 PM
