Well two months back, I got a problem with my stupid alternator and i was like fuck. also my climate controls sucked, cuz i hated the slider and by old age of the car, it started to stick and bind. Well fellas here is the solution
1. Alternator - 80 Amps - Efi Cars only
I went to autozone, got a 3g alternator and i was like, yo lemme see the 4g alternator, he brought it out, the lower mounting was exactly the same size in width. I was like hmmmm. The 4g alt is a 80amp and ours is only 65 amp. only $10 extra. I was like. Give me the 4g alternator. Brought it home fit it in perfect, all the clips go in great but the tilt was too much, Belt would not go over. So went to autozone got a couple of belts, even the dude was like, yo go behind the counter to the belt section and choose whatever u want and come and give it to me later. So i went there and found the right size belt ((the length i will give later)). put on the new belt, But it was kinda loose and the stock alt adjusting bolt was not long enough. So took a 10mm long bolt, the dist bolt and bolted the alt to the bracket and gook the adjusting bolt and put a non usable 3/8 inch socket on it and put the bolt back on and it works like a dream, im putting out 14.7 Volts under no load, and 13.2 Volts with everything on, high beams, fan, radio all doors open and trunk open with brake light on. so its more than good.
So yeah, with lil modification, it works like a draeam, i have put on 4000 Miles on it and its still going strong.
2. 4g heater contrls
You know the 4th gen accord has the knob style heater and fan controls right? Well it fits in perfectly and does not look like ass. My friend was like damn........ it looks better than stock. The black plastic on it matches our interrior plastic very good.
This is what you do. When u pull out the control from a 4g accord, take the clip connector in the back with long enough wires. U need the wires in the back with max slack.
THe wires are coded exactly the same way. so match it up and ur good.
The only problem is, the heater knob. It spins the other way than our 3g, so when u put it in cold, its warm, when u put it in warm, its cold. U have to spin the stupid coolent valve under the hood the other way around and hook up the cable.
The fan control on a 3g is 4speed and the 4g is 5speed, so u would be left out with a blue-red wire which is the max. U need to connect it directly to the blower input wire. and ur done
Im gonna be getting a digital cam in the next three weeks, so makre sure to check back for pic updates. :cool2:
