Hi guys, actually i have 2 options: Rebuilt my 1986 LXI BT engine or make my dream and put a powerfull engine in my ride...
I'm thinking in an B18C1 for swap, please i would like to hear your comments first. Any help i will appreciate it.
Thanks
Thanks
Accord86 LXI
San José, Costa Rica
Please read this thread. You'll find out what you need to know. Prepare to spend a lot on this swap. It's gonna run probably up to 7-8 grand.
https://www.3geez.com/showthread.php?t=17520
why would you want to dump so much money into it for vcrap when for you can go BOOST??? for the cost of the motor, you could almost have your motor rebuilt and turbo'd. . . . . . .
Nothin' 2 Old Racing
I though about swaping a B18C1 but the price and work of swaping it I could just buy a GSR or turbo the A20 for much less.
I would suggest a B16a2 over the B18c1. If done properly, you will have a better platform that the B18c1. The only thing that worries me is the weight of the car. A B16a2 with a 1.7L crank and a possile bore increase to 85MM.. 1.9L Goodness. You can always rebuilt the A20a3 w/ some High Comp Pistons, New Rods & Work on the head.
Well, I say go for the b18c1!!! I did, or rather still am piecing it all together, only real drawback id say is $$$. IMO dont buy a b16 - they are ment to power a civic, a car lighter than a 3gee . The lightest gsr teg that saw a b18c1 weighs the same as a fully loaded 4 door LX-i with a 2 liter IRON block engine in it, therefore significantly LESS than a teg when equiped with its engine. And as for boring a 1.6 to 1.9 y??????? Im sure you would be sacrificing lots of reliabilty, of course maybe you dont care, but my car is still my daily grind. Id say you have 2 options:
1) 6k (realisticly) for a reliable quik 200ish HP turbo A20A3 or BT using Sean's kit. probbly the best way to go if looking to save $$$
2) 8-10k (again realisticly) to get the b18c1 and a few minor to moderate power adders. 190 - 210 HP, but a much better platform with loads of aftermarket support and room left for boost.
Of course nobody is right all the time, so if you see an error in what ive said plz feel free to point it out.
Whatever road you go, it should be a lot of fun, and in the end you will be happy because even tho you couldve bought a used car just as fast with the money you spent, thats the lazy ass unoriginal thing to do.
- Matt
no turbo lag!Originally Posted by NXRacer
more relible!!
less constantly replacing clutches!!!
and finally.......
NEWER TECH!!: and no mater what u may argue otherwise it is a BETTER starting platform. More expensive? no doubt, but if you put an equal amount of work into that "vcrap" engine you'll smoke the crap out of a20s all day. :cool2:
- Matt
The GS-R is probably the worst engine out of the 4 B-series VTEC engines. It's the only one that does not make 100hp per liter. It's an easy swap because of it's torque, but it's not a high monster like the B16A/B or B18c-R. Still a good engine and it makes the most mid-range torque. 92-93 GS-R came stock w/ a B17a1 and it was a pretty decent car. The reason I suggested the B16 was because it's the cheapest B-Series platform and if you bore & resleeve, you will have a nice high reving power producing platform.Originally Posted by Project-LXi
Well I'm not so sure about beating the crap out of an A20. I have seen Civic's with the GSR swap pushing over 500 hp and only running mid 11's. Yet with the A20 you can have less hp for less money and still run side to side with the +500hp Civic. It's about the engine design the A20 dosen't need to have the shit reved out of it to make 500 hp like the B-series. Hey I wanted to do the GSR swap too with turbo but after I look at the total price of it I could turbo the A20 for much less $$$ and be just as fast.Originally Posted by Project-LXi
Maybe I just havent been on the site too much lately... but I have yet to see real 1/4 mile ET's or Dyno numbers for sean's turbo kit... and the lack of a strong enough clutch still bothers me.
I dont know what you are smoking... but the GSR we are talking about, was with the B18c1... it has 180HP if you get a JDM engine... if it is USDM, then 170hp. Either way, the B18 is a way better platform then the B16. It has more torque, larger displacement, and better potential than the B16.The GS-R is probably the worst engine out of the 4 B-series VTEC engines. It's the only one that does not make 100hp per liter. It's an easy swap because of it's torque, but it's not a high monster like the B16A/B or B18c-R. Still a good engine and it makes the most mid-range torque. 92-93 GS-R came stock w/ a B17a1 and it was a pretty decent car. The reason I suggested the B16 was because it's the cheapest B-Series platform and if you bore & resleeve, you will have a nice high reving power producing platform
My Project thread https://www.3geez.com/forum/project-c...dan-build.html
My Flickr: http://www.flickr.com/photos/jdmca5/
It's not a very popular platform in JDM Land for a reason.. It has the worst flowing head of any B-series head. If you notice the B18cR or B18c5 is built like a B16, has basically the same head and power peak points.. VTEC xover on a GS-R is 4400, on a B16, B17, B18c5 is 5600. GS-R is great mid-range engine, but it's the greatest High end engine. If you had read what I posted, you would have noticed I wrote 100hp per liter not total hp.Originally Posted by Hash_man_Se_i
A C1 swap is not worth the extra cost over a B16. You get 10 horses and approx. 11 more lb-ft. torque. Let me see $3000 for the B16 or $8000 for the C1. Also the B16 has a better rod/stroke ratio and better flowing head. The B16 head is second best flowing head behind the C5. You can make those 10 ponies up with the addition of a header back exhaust for another $700. That's just a guess too. You can probably get it cheaper. Also the B16A1 has no OBD issues and a cable tranny already. Plus it's the easiest swap to do besides the JDM B20.
Excellent! Sounds like your getting ones these??Originally Posted by SteveDX89
Well SEAN has posted some hp and tq numbers and they are pretty good, and the clutch problem is solved. SEAN found a place to make us a HEAVY duty clutch/ preasure plate, and an aluminum flywheel. It isn't a cheap package but it will hold anything you thrown at it.Originally Posted by Hash_man_Se_i
i was thinking of making my car a car that will be fun to take up the mountains. I'm already saving up (not exactly knowing what i want) but still saving up nonetheless.
does a B16A run into torque problems? or does generally a B series engine with vtec run into lower torque issues? Perhaps a b16a would be a viable engine for my purposes...but i'll research a little more. (besides i got a lot more to save up )
Originally Posted by Busted_Blue
Why would you want a Honda to take up to the mountains?? SUV'S!!
well then just keep the A20 and swap in the lude tranny. Those gear ratios will be better for quicker acceleration or going up the mountains. But still why take a car in the Mts, why not a truck that has some ground clearance?
Originally Posted by Justin86
sorry to put the wrong picture in your minds, but i meant, mountain roads. Similar to auto crossing but with the inclination involved.
http://www.pashnit.com/roads/cal/LickObservatory.htm
I've been loving this road since i started school in san jose which is 10minutes away.
Yea thats what I kind of thought but not every place has paved mountain roads. Half of the Mt. roads around here are paved and most of them are pretty rough.
Well, the car will be having fun in the nice roads around my area, as well as perhaps autox. Friend has a b18c1 sitting in garage with a y1 tranny for about 2grand..possibly. He crashed his teg and he took out the engine for us. anyways, IS this engine actually that bad of an engine as nuffice says? Noted that when I go around mountain roads, my RPM for my accord is usually in the middle of 3-5k rpm. Would the B18C1 be optimal for mid range torque? The GSR does have that dual stage intake manifold similar to the 89 accord manifold that hits at 5800 and the vtec hit at 4400. Sounds like an ideal car for mid range right?
Yea that should be a good set up especial with the Y1 tranny. If you can get the motor and tranny with the complete wire harness and ECU it might be worth it, then still all the mounting hardware is around $2,000 from Place Racing. So about $4K if you do all the wiring your self and thats a pretty good price for the swap.
IF the mounting hardware is around 1000 and the engine and transmission is around 2000 totoal where do you people get 10k from
ok so i can get a b16a1 with some things i need to put it in the car(wiring harness, tranny, ecu) . and it's obd-0 so i don't have to do a conversion right? besides the mounts how much to put it in? on https://www.3geez.com/showthread.php?...0&page=2&pp=20 it's apparently 8-9000? but that's with the conversion. i need the info before that motor sells!
I spent 5K to do the B16 swap. It's more than buying the stuff and dropping it in. You have stuff that breaks as you take it apart that needs replaced. You need to replace parts on the motor before you run it. You can half ass the job for cheaper but then you have reliability problems.
what stuff breaks as you take it apart. Some people can brake anything.
