Ok so in a couple weeks I'm gonna be replacing the OEM struts and cut springs with some stockies till I can start to make heads and tells with what struts work good with aftermarket springs and Coil Overs. My question is what is proper setting for rear stock sprins,with stock struts, and no lowering. Same thing for front struts and springs. How do you set the spring compressor. I'm picking a spring compressor up this week. Picking up the struts and springs next week. Thanks. I've got the Haynes and it isn't giving what to set the springs at unless I am looking in the wrong place. I'm also picking up a Chilton's this week as well.
