Results 1 to 4 of 4
Thread: DX/LX trannys vs. LXi/SEi trannys
    sporkHSP's Avatar
    Oct 2003
    87LX / 86LXiHB / 90CRXSi(b16a) all gone... 91CRXSi(b16a) ...round two
    St. Louis, MO
    i read some where on here a while back that the carb trannies had different gear ratios, and that they would have a higher top speed because of this... would it make any difference if i swapped one into an LXi...i might be getting one soon, and it needs a new tranny... i need a new tranny anyway, so i will be swapping, if it would make any positive difference, i would just assume swap in a carbed tranny for theo one its got in there now... its a 5speed too, and i want to keep it that way...
    thanks you!
    garagement racing
    stlhondas.com
    AZmike's Avatar
    Tucson, Arizona
    The gear ratios can be found here:
    https://www.3geez.com/showthread.php?t=165
    The tranny from a fuel injected car will give slightly better acceleration and a slightly higher top speed with a very small decrease in fuel economy. The only difference between the two is a ~5% higher final drive ratio on the FI transmission.
    Did you try a search? I posted the same information a few weeks ago for someone else.
    Mike
    2.0Si User Elijah's Avatar
    A20A3T
    Edmonton, Ab, Canada
    So u dont have to use a fuel injected tranny in a lx-i?If u dont does it have to be out of if my car is 88-89 can I use a 86-87 tranny?
    Thanks Elijah.
    AZmike's Avatar
    Tucson, Arizona
    As far as I know the only difference is the final drive ratio. The axle lengths and main shaft and axles splines should all be the same.
    Mike
  1. a few questions on trannys
    By teck in forum 3geez Accords
    Last Post: 02-12-2007, 12:16 PM
  2. Lude Trannys
    By AccordEpicenter in forum Performance
    Last Post: 04-10-2003, 07:44 PM
  3. a20 trannys
    By ryer_s in forum Performance
    Last Post: 04-08-2003, 06:33 PM
  4. What Accord trannys are compatible?
    By Stew Pidasso in forum 3geez Accords
    Last Post: 02-07-2003, 07:22 AM
  5. will lude trannys fit?
    By dXsquared in forum 3geez Accords
    Last Post: 05-08-2002, 10:48 AM
