Question ONE: I've got most of my stuff hooked back up, in regards to the head... However when I stand facing the engine bay and look down at the radiator there are two nipples that look like they'd like a hose attatched to them. If this isn't descriptive enough for you guys I'll take a picture, but its raining right now
*wine*
Question TWO: I pulled off the crank pulley, and the timing belt pulley? not sure what the technical name for this is. Anyway! Should you be able to put a finger at the right top side of the oil pan and run it all the way down the half circle to the other side smoothly? There is a peice of metal that almost looks as if it does not belong, however it is not coming off with gentle persuasion. Again, if this is not descriptive enough, which I don't think it is.... let me know and i'll have to find a way to host images.....
_ justin
