Results 1 to 5 of 5
Thread: Want to paint back bumper - Cant remove!
    DX User JakeEXLS's Avatar
    Ok, i have searched for:
    Removing Back Bumper
    Removing Rear Bumper
    Removing Fender
    Removing Bumper
    and one or two other things, and unless ive overlooked somthing, i cant find how to remove it!
    I want to take it off to paint it because the blacks gone milky grey and the white has scratches on it, and i dont want to mask it on the car because im going to take my time and its my only car, so i want to drive it...
    any help please? even if its just a friendly link to somewhere?
    Thanks Guys!
    sporkHSP's Avatar
    Oct 2003
    87LX / 86LXiHB / 90CRXSi(b16a) all gone... 91CRXSi(b16a) ...round two
    St. Louis, MO
    the bumper should be held on by screws in the wheel wells and along the top, underneath where the trunk comes down... you might have to play it by ear and slide it off some brackets afterwards, but it should be those screws...
    undo the ones you can see and then test to see where it feels like its still attached, thats where the slide brackets will be and maybe some hidden screws.
    its gunna take some testing before you get it off...
    garagement racing
    stlhondas.com
    Cheers for ideas spork, but the screws where the trunk comes down had nothing really to do with it, and im glad of that beacuse my were all rusted and when i did try to remove them, i couldnt because they were all rusty. You were right about the wheel well screws though!
    After a bit of playing around i found out how to do it.
    First, remove the mudflaps from the wheel arch and leave the screws out. Then, under the back there shoud be 2 or 3 bolts on each side. Take out the two closest to the back of the car. The third one in my case, is the main one that hols the towbar on. After removing all these, the bumper should pull directly back, with a bit of force. If it gets stuck, give it a good tug on each side near the wheel arch.
    (Just incase anyone wanted to know!)
    Post pics later
    Reason for doing this is that i want to re-black the black strip on the bumper, and re white the white bit. Again will post pics.
    sporkHSP's Avatar
    Oct 2003
    St. Louis, MO
    glad you got it off... i havent removed mine, i just remembered seeing the screws there, so i figured id suggest you look at those. glad i could help a little. (this is when i wish we had a smiley that patted itself on the back)
    garagement racing
    stlhondas.com
    Heres the picture. You can see the two square holes in the back - Thats where the brackets slide into and have bolts that come up from underneath. Then there are just the screws in the wheel well that are also holding the mudflaps on...
  1. [Appearance] Install Remove Front Bumper
    By Knowledge Base Admin in forum How To
    Last Post: 03-17-2006, 12:39 AM
  2. How to remove road paint overspray?
    By frantik in forum Interior & Exterior Care
    Last Post: 01-02-2006, 08:38 PM
  3. Black spray paint on body. How to remove?
    By mnbv in forum Interior & Exterior Care
    Last Post: 04-13-2004, 09:50 AM
  4. how to remove front bumper?
    Last Post: 09-04-2002, 07:34 PM
  5. remove rust without a whole new paint job?
    By accordster in forum Interior & Exterior Care
    Last Post: 05-19-2002, 04:01 PM
