Results 1 to 15 of 15
Thread: B18b1
    Feb 2003
    89 Accord DX hatchback
    Ajax, Ontario
    B18b1
    how much effort and money would it be to convert my carb to a B18B1?
    my main concern is wiring... i was thinking about a fuel cell instead of a gas tank.
    B18B1 = 96-00 integra gs, 1.8 dohc, non-vtec
    its not how fast you go, its how fast you get going.
    if you want non-vtec motor, B18B1 would be great for dual weber sidedrafters setup.
    the only problem is that you will have to spend over $1000+ on B series Engine mounts, shift rods, and axels.
    plus don't forget you will have to buy weber carbs, new intake manifold and many other little things.
    the total cost can be way over $3500 easy just for parts.
    now, if you want to convert to EFI, you will need half of EFI 3geez. that can cost you between $250 and $750 depends where you buy the parts.
    so think what you want to do.
    Mike's89AccordLX's Avatar
    Mankato, Minnesota
    I think its cheaper to convert to EFI and get a JDM B20 or a B16. That way you will have more hp and be fuel efficient. Don't get me wrong I love my carb, but I know it's not as good as a good fuel injection setup.
    SteveDX89's Avatar
    2002 Mazda Protege5
    New Freedom, PA
    Don't forget the B18B has a hydraulic clutch so you have to do a conversion or get a tranny from a non-VTEC B-series with a cable tranny such as a B18A. You will have to run a new gas line for EFI and switch all the wiring in the engine and cabin. It's a lot of work. You just have to be ready for it.
    Mankato, Minnesota
    That's part of the reason why I'm keeping my accord carbed. I know it probably wont be as fast as my 94 lude si so I won't drop as much money into the accord now. But I will make her look purty I'm planning on buying some good lowering springs after I get one of my bills paid off. And a custom paint job with a double front lip and custom rear lip.
    So she will look nice when its done.
    Feb 2003
    Ajax, Ontario
    well i need to take my engine out because my main seal is leaking like a mofo so i figured if the engine is out then why not rebuild or replace seals then i was like well i could just put in a new/better engine in. i dunno what to do, what do i have to do exactly to convert to EFI?
    SteveDX89's Avatar
    2002 Mazda Protege5
    New Freedom, PA
    http://pages.infinit.net/omus/
    That's a link to Carotman's site. He has a how-to on the FI swap. Keep in mind though using a B-series engine will require less parts and work for the FI swap. Some parts and procedures are for the A-series only.
    1987 Hatchback phreak project
    NORTH BAY ONTARIO
    PIP... i got a source for a parts car with EFI... we could do the swap this spring... oh yah.. bring your damn car up soon.. its getting warm out
    Travis
    Banned Nuffice's Avatar
    Feb 2004
    89 Accord
    Omnipresent
    You don't have to convert to EFI.. You can have a shop make you a standalone harness. I have seen shops do it and it works well. The only way to use a hydro tranny is to convert to hydro, There are no premade kits. Hasport Cable to Hydro is made for Hydro cars wanting to use cable trannies.
    Feb 2003
    Ajax, Ontario
    i'm thinking of just finding an A20A3 and running an EFI engine, bolts in less head aches, less money, better platform
    Oct 2002
    1986 Accord LX 2BCarb/5spd
    Sacramento, CA.
    What about the standalone efi system I read about somewhere? Someone had a GM efi kit or something to that effect.
    Gone thru two minivans and two sports cars, but my accord keeps on going at 254,000 miles. Actually, it died. But here comes the JDM B20A!!!
    Accord owner since 1995
    Feb 2003
    Ajax, Ontario
    what is standalone? what does it do?
    Oct 2002
    Sacramento, CA.
    It's an EFI conversion that hardly connects to anything on the accord. It has it's own ECU, sensors, etc....
    I just may do this when I get the money. I just started a new job after not working for over a year, so now I can finish my JDM B20A swap. My problem is that I have a carb'd 4-door LX ('86), which is causing alot of little tedious headaches. So this sounds like a good option than converting over to the stock EFI. Here's a thread that talks about it....
    https://www.3geez.com/showthread.php?...ghlight=gm+efi
    I would just recommend doing a search on GM and EFI though. That way you get the complete 411.
    carotman's Avatar
    Montreal South Shore
    Well, you don't need to worry about the hydro clutch on a B18B1 swap. All you need to do is use a 90-93 teg trans.
    Feb 2004
    89 Accord
    Omnipresent
    Make sure it's a PRE-OBD Tranny.
  1. b18b1 for sale on craigslist
    By moliassa in forum For Sale
    Last Post: 07-08-2009, 05:24 PM
  2. B18B1 in a 3g accord?
    By capoA20A3 in forum General Engine Swaps
    Last Post: 02-03-2004, 04:14 PM
  3. B16 or B18B1?
    By Oakenfold in forum General Engine Swaps
    Last Post: 11-28-2003, 09:43 PM
  4. B18B1 LS Motor for sale...
    By capoA20A3 in forum Trading Post
    Last Post: 10-28-2003, 07:55 AM
  5. b18b1 in northern bama area...fs
    Last Post: 10-23-2003, 07:53 AM
