Results 1 to 4 of 4
Thread: We've got a code 12
    LX User mag_pbg's Avatar
    1992 Acura Integra
    Kansas
    We've got a code 12
    I was driving around the other day when my check engine light came on, so I pulled over and got the 'ol haynes book out and checked the ECU which read code 12, my question is will this cuase any serouse (sp) prob. I know alot of people have removed thier EGR's but will it not functioning right matter¿ My car still drives the same i havn't had any prob. so far but a freind of mine said that it could cuase me to burn up my pistons or something like that.
    "Popup headlights the pinnacle of 80's technology"
    Ram air intake bored out throttle body MSD Blaster coil Advanced ignition Ported Head with 3angle valve job and shaved Delta 260 cam Pacesetter header 2.25inch exhaust Mallory Hyfire 6
    shepherd79's Avatar
    Falling Waters, WV USA
    it won't cause the piston burn up.
    all it does is recirculate the exhaust gases to reduce the emissions.
    try this. remove the EGR valve and use some carb cleaner to clean it, when you clean it, push on the piston this way it will clean inside too. if that doesn't fix the problem, you will have to replace the unit.
    1992 Acura Integra
    Kansas
    Thanx shepherd79 I will have to do that tomorow after school, if that doesn't work would it be easier if I just clamped that metal hose, and plugged the 02 sensor on the exuast manifold.
    shepherd79's Avatar
    you need the O2 sensor for your ECU and you need EGR for your ECU. stupid american emission laws. when my EGR valve was bad, i had bad gas mileage, plus uneven idle.
  1. code 12
    By VIPER1988 in forum EFI Tech
    Last Post: 06-08-2010, 06:17 AM
  2. Ecu code?
    By honda in forum EFI Tech
    Last Post: 01-12-2008, 05:53 PM
  3. Help with TDC code?
    By HC_LXi in forum EFI Tech
    Last Post: 01-02-2006, 11:20 AM
  4. EGR code (12) will not go away
    By gofast in forum 3geez Accords
    Last Post: 03-10-2005, 12:23 AM
  5. Code 8..
    By 88' Accord Ltd in forum 3geez Accords
    Last Post: 06-17-2003, 02:26 PM
