Results 1 to 4 of 4
Thread: Timing Belt
    Oct 2002
    86/Honda/Accord lxi
    Orlando, Florida
    Timing Belt
    Hey you all whats up? I bouth a 1996 civic about 2 months ago. And it currently has about 75K miles on it. I was wondering how do you know if the timing belt needs to be changed? I keep hearing people saying at 100K or 60K. i am not sure if the timing belt as been changed and if i get a machanice to inspect it would they be able to tell? I know that this isn't a civic form but you all have been help full when it came to fixing my 3 gen and i taught i would give it a shot.
    PHILIP
    It's not the size of the dog in the fight, but the fight in the dog.
    LXi User DanLXI88's Avatar
    Mar 2004
    1988 Honda Accord LXI, 90 Caddie 90 Chevy
    Columbus, Ohio
    When in doubt JUST DO IT. After you get it done you'll have peace of mind in knowing..
    **Some Info on my car can be found here **
    http://www.cardomain.com/memberpage/547146
    Moodybluesr's Avatar
    Jan 2004
    1991 Subaru XT6 AWD, 1988 Subaru XT6 AWD
    Urbana, IL
    A timing belt should be done every 60k miles. In order to adequetly inspect a timing belt, it must be removed; if you remove your timing belt you may as well replace it. While you are at it, have the water pump replaced as well as the other drive belts on the engine.
    Jul 2003
    1989 2DR coupe LXI
    Northeast PA
    The newer Honda's are due at 90K. Check your owners manual in the required maintenance section. It will tell you when the belt is due to be replaced. The new Honda's are due at 105K.
  1. I need timing belt help
    By dmitch31 in forum 3geez Accords
    Last Post: 05-30-2007, 10:40 AM
  2. Timing Belt
    By 89HondaAccord in forum 3geez Accords
    Last Post: 03-10-2005, 07:54 PM
  3. Timing Belt
    By 89HondaAccord in forum EFI Tech
    Last Post: 03-09-2005, 04:30 AM
  4. Timing belt
    By 89AccordLvr in forum 3geez Accords
    Last Post: 03-20-2003, 05:13 AM
  5. Timing Belt.....
    By 3G Jester in forum 3geez Accords
    Last Post: 01-03-2003, 12:06 PM
