Hi,
Let me just tell you at the begining that my carb is free af all the diaphragms and vacuum stuff. Secondary is mechanical, no idle regulator, no AC booster... The only thing left was choke but it started giving problems (unloader) so I got rid of it as well and now the choke it's stuck open waiting for manual conversion.
Now... this nice clean carb has nothing else connected to the throttle but throttle cable... Everything is just fine most of the time but now and then, when driving for same time the idle goes up to 2000 (normally about 900) and wont go down... I always thaught that the RPM depends only on the throttle but apparently there is something else. Do you guys have any suggestions other than weeak spring or stuck cable? The idle goes down I run the car next time.
It just bothers me. I'd like to heve total control of this carb. Thanks.
Greg.
