Results 1 to 2 of 2
Thread: lx compared to lxi trans
    1986 accord hatch with 89 lxi engine
    miami
    Question lx compared to lxi trans
    is there a difference between the lx and lxi transmissions. which one is better and which has the best ratios
    I don't need speed, I just want it.
    PhydeauX's Avatar
    Eastern Penna
    84-87 Prelude Si. The LX-i is geared sportier then the LX, but the prelude is the sportiest. They all have the same case and are interchangable. If you are going to swap the trans might as well go for the lude, it'll cost you just as much as the accord. The 84-85 1.8 Prelude is actually the sportiest, but it requires you to swap the clutch and flywheel from a 1.8 prelude too, the Si's is a direct fit.
    andy
  1. 88 trans into 86?
    By 45psi in forum Performance
    Last Post: 04-12-2012, 04:42 PM
  2. a20 trans
    By firefighterwhite89 in forum EFI Tech
    Last Post: 09-25-2011, 04:45 PM
  3. 86/87 compared to 88/89 ECU, how can you tell them apart?
    By newaccorddriver in forum EFI Tech
    Last Post: 10-11-2005, 05:58 PM
  4. Same trans in LX and LXi?
    By DCD1278 in forum Classic Honda Community Chat
    Last Post: 09-25-2003, 02:07 PM
  5. got my teg trans
    By flamed89 in forum Performance
    Last Post: 07-11-2003, 03:40 PM
