Results 1 to 7 of 7
Thread: problem~ quick need help!!~
    Busted_Blue's Avatar
    Jul 2003
    93 civic
    San Francisco, CA
    lowering with tokico spring/struts problem~ quick need help!!~
    ok i got my rear struts off, the springs are off, im installing tokico springs on tokico struts...the problem is that the spring isnt fitted properly on the top! the bottom fits nicely but the spring is shorter than oem so the top of the spring isnt snuggly fit with the top of the strut! what am i doin wrong?! need an answer quick! thanks.
    2.0Si User lightbulblxi's Avatar
    Aug 2003
    88 accord lx-i coupe 5sp.
    pulaski wisconsin
    are u saying that the spring is shorter than the stock ones so it isnt ushing up on the top of the strut? if that is the case than it just means that u will have a slight drop, when i put my dropzone springs on, they were a bout half the length of the stock ones, if u push the strut down it should be onm the spring.
    -Brian
    My Accord
    Jul 2003
    93 civic
    San Francisco, CA
    Now both are in and the left side is lower than the right. The Left was the side that was loose.But the right was very snug and no movement. Any thought?
    Aug 2003
    pulaski wisconsin
    do u have the top of the strut tightened all the way?
    -Brian
    My Accord
    Sep 2003
    1988 Honda Accord LX
    Ajax, Ontario
    bushings on correctly??? hows the alignment of the springs???
    Jul 2003
    93 civic
    San Francisco, CA
    everything is on tightly, but one side is lower in the rear. it was installed correctly, but one side on the rear, the spring has a wobble, the other side has no wobble and is snugged. I'm doing timing belt, ps belt, alt belt right now so the fronts arent in yet. They fit fine in the mounts out of the car, so only the driver side rear has a wobbly spring. I'm not sure if they are actually shorter or not, i might have to take it back out and see
    the rears are not parallel, its slanted with the passenger rear higher
    Jul 2003
    93 civic
    San Francisco, CA
    well, nevermind. Seems like when i put everything down it still was remotely similar balance. I'm still wondering about the wobble, since ONE side on the rear springs was wobbling and the that doesnt go really easy for me. Well, my car is down now, since my dad and I were having trouble with the crankshaft pulley bolt, and our air gun didnt have enough power to take it out. So, my car is down for now, but it looks great!
  2. Replies: 7
    Last Post: 08-11-2005, 04:17 PM
  3. Whats wrong with my car? hesitation problem & starting problem!
    By gsus in forum Classic Honda Community Chat
    Last Post: 08-11-2005, 08:04 AM
  4. Replies: 5
    Last Post: 01-25-2005, 04:04 PM
  5. Quick Quick help (subs)
    By Jerren in forum Interior & Exterior Care
    Last Post: 05-24-2002, 09:29 AM
