Just wanted to pass on this info .I tried this process of rust removal on some tools and it works pretty good.Example, I found a Vice Grip laying around that had rusted up,the adjusting screw wouldnt turn and the spring was trash, I oiled it and got it to work so so, when I saw this process I put the whole thing in the bucket completely assembled and it came out fine, didnt harm the chrome,I did a set of feeler gages, again it just treated the rust and left the numbers intact (I dont know if they are acid etched or painted) so if you need to remove rust this method is a lot easier and will work without damaging the metal.http://www.stovebolt.com/techtips/ru..._derusting.htm
