Yo, I just bought my 3gee, $500, it needs a bit of work. When I accelerate to 3000 rpm, it seems like it cuts out? Any ideas?![]()
It sounds like either a fuel or ignition issue.
Try changing the fuel filter(s), air filter, cap, rotor, plugs, wires if they look bad and set the timing.
Do you have carb (dx, lx, ex) or Fuel Injection (LXi, SEi, EXi)?
Maybe a loose booster venturi...
check here:
https://www.3geez.com/showthread.php?t=30494
oops... thats right, are you carbed or fuel injected?
I assumed yours was cared in my post.
Its an EXi
So can anyone help?
I allready threw out a few suggstions.Originally Posted by Richy833
Since you have FI I would reccomend checking to se if the throttle plate in the throttle body operates correctly.
most likely your fuel filter is dirty. replace that.
clean spark plugs. or replace them.
check ECU for any codes. the ECU is under the driver seat.
move the seat forward and open the little window to see if the light blinks. if it blinks, count the blinks.
what do i do when it blinks? it only blinks when i turn the key.
Yep, the key has to be on, look under the seat in the fold down window and count the blinks. This will give you the trouble code.
yea, its the oxygen sensor A. my dads fixing it right nowCant wait to get my permit
nice glad to hear things are looking good start with a basic tune up don't forget to clean the throttlebody and work from there
