Results 1 to 14 of 14
Thread: quick advice on brakes please? . . . . . . . . . . .. .. . . .
    chicago , il.
    okay my brake's are worn again?!
    okay so now's my oportunity to upgrade to lx-i brakes.
    so to up grade i know i need the
    lx-i caliper's
    lx-i brake pads
    lx-i rotor's
    but do i need the bolt's that hold the caliper's in place or can i use the same from the lx????
    and can i use the same screw that hold the rotor's in place or do i have to use a different one????
    thanx!!!!!
    NXRacer's Avatar
    86 LXi Hatch
    Tri-Cities, WA
    you also need the knuckles from the LXi since they're bigger then the LX brakes. Mario found that out the hard way.
    Nothin' 2 Old Racing
    chicago , il.
    what but i thought that's all would be needed.
    why would you need the knuckle.
    k-roy's Avatar
    87 LX
    You need the knuckles because the rotors are larger and the calipers are mounted differantly.
    Oh and if you still have your stock 13's you need to get larger rims so the calipers don't rub on the inside of the Rim.
    chicago , il.
    that's one problem taken care of i have 15's
    okay so will the lx brake system handle the efi once i finish my conversion??
    Busted_Blue's Avatar
    Jul 2003
    93 civic
    San Francisco, CA
    don't you need a new master cylinder also?
    wprocomp's Avatar
    Armrest whore
    yep
    the lx brake system will do just fine...its until you decide to really do upgrades for speed that you will some stopping power
    LX User Defiant[YD]'s Avatar
    89 Accord Sedan LX, 91 ED-7, 2007 Accord EXL
    Cow Town, Calgary
    well, if the new brake setup is gonna be larger than ur current one, wouldn't it be better to get slotted rotors instead of lx-i ones? unless there aren't any aftermarket ones yet.
    no offence intended, i'm just wondering cuz i'm thinking about doing the same thing.
    1989 Accord: Back to Stock
    2007 Accord: Stock
    1991 Civic SI: bunch of stuff done.
    chicago , il.
    um . .. yea but i don't have that kind of cash.
    Cow Town, Calgary
    oh ok. no offence intended accordlxi2.0 i just wanted to know. cuz over here they're charging me more for lxi rotors than aftermarket slotted ones. and of kose, i just realized that u have access to an lxi.
    2007 Accord: Stock
    bobafett's Avatar
    Stock 86 Accord LXi Hatch
    Longview, WA
    while we are on the subjuct, what would an 86lxi need to upgrade to the 88-89 lxi setup?
    just give a list of stock parts that need to be collected. i can sort thru and figure out what i want to be aftermarket or not.
    you will need:
    rotors, calipers, brake pads, hubs, master sylinder and proportion valve.
    bobafett's Avatar
    Longview, WA
    thanks shepard
    chicago , il.
    okay okay so do i need the knuckle's or not??????
  1. Big Brakes and Addco rear sway bar on sei brakes
    By EricW in forum Classic Honda Pics & Videos
    Last Post: 10-01-2007, 01:13 PM
  2. quick advice
    By Bigmaxxin in forum 3geez Accords
    Last Post: 07-17-2005, 10:34 AM
  3. Switching carb brakes to EFi brakes...
    By Hash_man_Se_i in forum Suspension/Wheels/Tires/Brakes
    Last Post: 02-21-2005, 04:09 PM
  4. Replies: 5
    Last Post: 01-25-2005, 04:04 PM
  5. QUICK HELP! My brakes don't work right
    By 87DXHatch in forum 3geez Accords
    Last Post: 07-16-2003, 10:44 PM
