I have a 86 LXi. I have just finished a complete cooling system flush (got all the rust flushed out) and also changed the faulty thermostat with an OEM thermostat. I have noticed the following temp gauge readings (assume from C to H is 100%, I will use the % to indicate the needle position. Say 50% is right in between H and C):-
In the morning, when outside temp is about 55-60F, the needle stabilized at 25-30% (the needle is almost horizontal) at highway speed.
During midday, when outside temp is about 75-80F, the needle will stabilized at 40% (I think this is the ideal temp) at highway speed.
In stop and go traffic during midday, the needle rises to 50 to 55%. At about 60-65%, the radiator and A/C fan kick in to maintain the temp at about 50 to 55%.
Based on my experience with other cars (non-Honda), the temp gauge usually "glued" at 50% once the car has warmed up. But my LXi's gauge will swing depending on outside temp and driving condition. Is your 3G doing the same or just me???
Idle RPM issue:
Also, I seem to be unable to bring my idle RPM down below 1000. Even the engine is completed warmed up and the adjusting screw on the throttle body is all the way in. I know this is no big deal but just wondering if anything is off making it not working within design range.
Thanks.
- Alex
