Results 1 to 2 of 2
Thread: Rotors squeal in reverse only.
    SEi User Dibbs's Avatar
    May 2003
    '86 LX-i Hatch
    Houston
    Any ideas on this? I can turn the rotor w/ my hand and it just squeals. Is this an issue of the rotor being glazed? I've got plenty of brake pad all the way around. On thing is that the right hub assembly is about shot. and the left one is starting to get loose. Could this be the contributing factor?
    Quote Originally Posted by kroy
    Mad props to you if you can pull it off, you can change your name to slowassoldschoolswap :thumbdown
    wprocomp's Avatar
    Armrest whore
    could be,I would go ahead an repalce them before anything else arises...funny thing...mine where doing the same exact thing...went through hell trying to figure out what it was right...well all it ended up being was the little bracket that holds the pads in on the caliper was messed up,give that a check and see what happens
  1. High pitched rear brake squeal when cold...
    By offthahook in forum 2geez Accords
    Last Post: 05-05-2006, 12:21 PM
  2. Constant Squeal
    By halxi in forum 3geez Accords
    Last Post: 06-09-2005, 07:33 PM
  3. Quick help please anti-squeal pads
    By A20A1 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 03-20-2005, 10:53 PM
  4. TB chirp/squeal
    By CASH24 in forum 3geez Accords
    Last Post: 04-21-2003, 09:05 PM
  5. Brakes squeal when not pressed...
    By 2Fast4U86 in forum 3geez Accords
    Last Post: 11-13-2002, 12:25 AM
