Results 1 to 25 of 36
Thread: cooling fans on when car is off???
    Jan 2004
    87 accord lxi 5-spd
    Rochester, NY
    anyone know why my cooling fan might be staying on when the car is off? i have noticed this for a few days now, that when i turn off the car the fan is still running.
    Idaho
    That's because the little Honda people over in Japan designed our cars like that, to cool the engine off.
    Jan 2004
    87 accord lxi 5-spd
    Rochester, NY
    how long is it supposed to stay like that? its ok for the battery im assuming?
    2.0Si User cubert's Avatar
    Feb 2003
    2012 Civic si, old bikes.
    NH
    yea..its ok for the battery. im not sure how long it stays on for, i wouldnt really worry about it though
    2.0Si User accordlxi2.0's Avatar
    1986 honda accord lx (r.i.p) 1990 acura legend LS
    chicago , il.
    um it has like a relay/timer for about 15 minutes.
    SEi User BMS's Avatar
    Nov 2002
    88 LX / 97 Teg
    California
    Mine never stays on. In fact just yesterday I parked my car and opened my door. I heard the fan come on when I did. About 5 seconds later I turned it off and the fan stopped as well. Maybe different years/models are wired differently.
    Nov 2000
    Mine stays on for about 15 minutes once the temperature outside gets above 85 or so. It is just the smaller fan on the driver's side that stays on.
    LX User Volitech's Avatar
    Oct 2003
    91 civic hatchback JDM ZC swap, Yamaha FZ600
    Madison, WI
    I had that problem but mine would start up at just randomly in the middle of the night!
    I fixed it by taking off the a/c fan along with the pump and lines! Works great now!!
    Chrome and paint don't equal speed and horse power!!
    2.0Si User zero.counter's Avatar
    2006 Nissan 350z
    Does school count?
    Quote Originally Posted by BMS
    I concur. I have yet to have experienced this issue. My fans are currently wired on constant however...
    natsugusa ya
    tsuwamono domo ga
    yume no ato
    Not like a rock's Avatar
    86 EXi(sold), 89 SE-i auto, 89 SE-i 5spd
    Prince George, North BC, Canada
    It's just your turbo cooling down. Tell that to people who point out that your fan is on.
    Perfection is simply a matter of replacing parts.
    shepherd79's Avatar
    Falling Waters, WV USA
    i think the fans stay on only on EFI models. i never had this happen on my LX, but since i have LXI see that all the time. it is normal.
    Vinny's Avatar
    Aug 2003
    Here, not there
    88-89 LX-i's fan's will run after the car is shut off. They (88-89 LX-i's) Have a secondary thermal switch in the thermostat housing similar to the one in the radiator. They also have a seperate fan timer under the passenger seat. Its an 88-89 LX-i only thing
    86LXItooFAST4me's Avatar
    Dec 2003
    1986 Accord LX-i *** 2002 Mustang GT
    Austin, Texas
    mine does that and its a 86 lxi. and sometimes when it is warmer than usual it wel kick on and off once or twice. i think it actually reads the temp and turns the fan off and on maybe. at least thats all i can think of because if it were timed than it would kick back on after it shuts off unless there is some kind of short??
    "Seriously, I have a half o' pack of Rolaids in my dipper" -Stewie (Family Guy)
    Car Pics
    vBGarage
    LXi User AC439's Avatar
    86 LXi
    FL
    My 86LXi did the same thing too ! But the engine was running a little warm due to a faulty thermostat. After I changed it to the factory OEM stat, it has never occur again.
    My theory is: - The faulty thermostat was not letting enough coolant flow so the engine block is warmer. The secondary thermo switch on the thermostat housing then turn on the fans to try to cool it off (but they were cooling off the radiator) so after 20 mins, when the engine block temp drops, the 2nd thermoswitch will cut both fans off. If the fans are turned on by the 1st thermoswitch on the radiator, it should only runs for a few minutes since the fans are cooling down the radiator itself directly.
    Apr 2004
    2005 Subaru Legacy Limited
    New Hampshire
    Most cars will do that... It's quite normal under warm conditions. Read the warning label on the fans... That's why you pull the positive lead on the battery when working on your engine .
    Mar 2004
    1993 Acura Integra B18A1
    Stockbridge Ga
    I was just going to point out that it is only the lxi that stay on for a "long" period. My Dx doesnt and the lx of my friends doesnt but my girlfriends brothers sisters lxi stays on forever!
    Jan 2004
    Quote Originally Posted by Vinny
    The 87 LXi's have the fan timer under the passenger seat also...I found out the hard way as it was draining my battery because it went bad...I would also like to mention my fan never runs when I shut the car off because it is wired to on constantly when the car is running.
    10/Honda/Ridgeline
    NJ
    Quote Originally Posted by unc25
    not to side track here, but isnt it the same as your girlfriend's sister?
    Re: cooling fans on when car is off???
    Quote Originally Posted by smufguy View Post
    lol
    My fans were staying on yesterday, 87 Lxi. It has only done this once before but it is very discerning.
    Dec 2010
    87 Honda Accord LX-i 5sp sedan 87 Honda Accord LX-i 5sp hatch
    Jack, Alabama
    I have 2 87 lxis and they both do it. There's a fan timer under the passengers seat and a fan switch in the tstat housing. Btw this thread is 8 years old
    I know, my 87 is older than anybody elses lol
    Roo, I think you win the random thread bump, wtf award for tonight. LOL
    LX User vteckiller's Avatar
    Oct 2011
    1989 Honda Accord LX-I
    OR
    my 89 lxi coupe does it every single time.
    LIFE IS SHORT, DRAG IT OUT!
    Hey there are hundreds if not thousands of bump deserving threads in here.
    Quick question: what would cause the fan to not turn on, ever?
  1. cooling fans
    By oscwrestler in forum 3geez Accords
    Last Post: 06-20-2008, 06:18 PM
  2. Civic cooling fans
    By 2oodoor in forum Restoration & Custom Fabrication
    Last Post: 06-13-2008, 09:57 PM
  3. cooling fans
    By labeledsk8r in forum 3geez Accords
    Last Post: 07-06-2006, 09:00 PM
  4. Cooling Fans
    By HondaBoy in forum 3geez Accords
    Last Post: 11-30-2003, 10:56 PM
  5. FYI...if your cooling fans won't come on....
    By Jareds 89 LX-i in forum 3geez Accords
    Last Post: 12-11-2002, 10:41 PM
