The ECT sensor on Hondas will many times fail. The typical pattern is that they look fine at normal temperature, but go "cold" as the car approaches normal operating temperature. You can see this easily by monitoring the sensor voltage. It will start high and will be dropping towards .5 volt and then take off to a high voltage reading again. Some even will bounce around from high to low voltage. The screen capture to the left is a voltage waveform of a malfunctioning ECT sensor on a fully warmed Legend. The ECT voltage would jump from .6 to 4.5 volts.
So now the engine control module (ECM) thinks the car is cold again, when it is actually at normal operating temperature. This really does not create all that much of a problem while the car is running. The injector pulse width (PW) will only vary about .5ms from full hot to full cold.
The problem is when you cut the car off and do a restart. When the ECM "sees" a start signal and a cold signal at the same time it increases the injector PW from the normal running width of 2-3ms to as high as 100ms. A hot engine typically can not handle this much fuel, and the engine floods.
