alright ive been searching but cant find exzaclty what i need to know. I bought a b20a from a 3geez member here wendsday and im trying to figure out a few things out about it. I planning on starting the swap on sunday. Alright i have the 88-89 style black top b20a. My car is a 86 with the bt motor. I am trying to figure out what would be the easiest way to wire it all up because i know the wiring harness are different and the intake manifolds are different and the ecus are a tad bit different between 86,87 and 88,89 mine has the secondary butterfly valves on the b20a. What would be the easiest way to get this to work for me. Should i use my manifold on it or try to get this one on the b20a to work. It also has the 2 oxygen sensors on it and mine only has one, would my ecu resond to this well? I am planning on eventually converting it to all run on the b20a5 ecu. But this is just for now! THANKS!
