Results 1 to 25 of 28
Thread: clicky rattling right after shift or pedal far down
    LXi User johnwc723's Avatar
    Feb 2003
    89 LX-i 5 speed
    Madison, WI
    hey guys i have been having this problem rescently and im just hopin that it aint pre-dentination
    ill be drivin my car around and lets say i am to shift but maybe shouldnt have shifted quite yet so im in a lower rpm, (even happens sometimes at normal shifts) when i push down the accelerator a bit i get the rumble cause i have the CAI but i also get this sort of rattling noise that comes from the engine area
    this also happens if i just floor the accelerator if it is in gear (not a really low one)
    anyone had this happen, the noise sounds like a rattling kinda but comes definetly from the engine compartment, i sorta thought it sounded like a deseil engine a little, i think i have heard other cars do it before too but im worried!
    Check out pictures of my car HERE
    "drop a 150 shot of NOS sticker on that bad boy and you can run 8s" -portugalfocus
    DX User momo8517's Avatar
    Aug 2003
    1990 Honda Accord LX
    Ithaca, NY
    hmmm...
    i used to get the same thing in my 90 accord...as it turns out the is (well, somewhat) normal. the car will run a little rough if you floor the throttle in a gear in which it can't accelerate very fast. so it'll rumble a little if you put it to the floor in the lower (0-2500) rpm range, and with the rumble will come a resonance of anything that's loose in your engine bay or in your entire car. i looked at mine and it turned out that the hood latch was a little loose.
    you may also have a c/v joint or boot on its way south, depending on what the noise is / how loud it is. if youre not really mechanically inclined, have a shop give the car a quick once-over. most places will do this free or really cheap. or, if you have a friend you trust to know a good deal about cars, have them look at it. but i doubt you have a problem.
    1990 accord.
    5-speed.
    bobafett's Avatar
    Stock 86 Accord LXi Hatch
    Longview, WA
    my car used to do that a lot, i switched to premium gasoline, and now it cuts down a lot, but it still happens, i usually just back off the throttle for a second and then ease back onto it.... its a PITA though
    i assumed it was predetonation too!
    SEi User BMS's Avatar
    88 LX / 97 Teg
    California
    My car does the same. I mostly notice it in 4th when I'm trying to pull from about 1500 rpm. If I put it in 3rd and keep it above 1800 or so the car is fine.
    Feb 2003
    89 LX-i 5 speed
    Madison, WI
    wow thast rediclous, yeah im gonna try dat premium fuel, anyone else have any insight if it may be pre-detination? sheesh its not like our cars have that high of a compression ratio!
    its good that people can concur with this tho! damn it sounds super ghetto tho, you get this nice deep sound and this rattle rattle ! (i think it must be somthing mechanical but ill check for stuff that might be loose)
    bobafett's Avatar
    Longview, WA
    could just throw in a bottle of octane booster for now and see if it helps at all
    yeah it makes me nervous when i race cause i dont want to let off the gas but i have to if i dont want to risk fucking up my shit.
    sheesh u guys drive at 1500, and 1800 rpms? i like to keep them at least at 2500 or above. amber always shifts so early it drives me crazy. heheh
    88 LX / 97 Teg
    California
    I shift at 2500-3000. Every now and then I pull 3rd to 5k or so getting on the freeway. Normal driving I average ~1600 in the city
    bobafett's Avatar
    Longview, WA
    man i cant stand driving that low of rpms, it feels like im just idling along lol
    88 LX / 97 Teg
    California
    I have enough "power" to keep up with city traffic shifting at 3k. I see no need to go higher. Maybe that's why my car is still goin for so many miles. I figure that for every rotation of the engine I can save now by keeping it at low rpms, I'll get that many more added to the life of my car. By keeping it low I very well may be adding life to my car.
    if you are in low gear and low rpm giving it gas making that clanking sound, its just "bogging down". thats something a lot of cars do. or, you can also check to see if your low on oil. i know that will cause that clanking sound in low rpms.
    2007 pilot
    Lv, nv
    depending on how loud the clicking noise is, it could be your valve clearance. I'm probably way off, but its worth a shot.
    Feb 2003
    89 LX-i 5 speed
    Madison, WI
    alright koo koo, yeah ill check them valve clearences and the oil and try some HQ gas next time too and see what they do
    thanks for dat help guys!
    SEi User MoonScryer's Avatar
    1986 Prelude 2.0si turbo - 1990 Integra moutain carver - 1993 Nissan 300ZXTT w/ more power than god
    Atlanta, GA
    I've got the same problem on the engine I put in the car. There was a bent valve which had to be replaced. When the engine is under load, or when you put your foot into the gas, the random clicking sound happens. When going for normal driving, without footing the gas, there is no noise.
    I've long suspected the valve that was put in wwas not adjusted correctly; guess I'll be checking the tension on it, etc. I'm just hoping I don't have to pull the head again and have the valve reseated, or something. I do that, I'm just going with a performance setup on a new head.
    I am the wrath of the server you curse and the demon of the directory you cry about - making life hell for users, one deleted file at a time.
    Feb 2003
    89 LX-i 5 speed
    Madison, WI
    shit maybe its that too. damn damn damn.... ill probably end up running a compression test i guess that would show if i got some leakage in any of my cylinders! (woulndt a bent valve cause some leakakage?) hmm imm gonna hit up them valve clearences too
    88 LX / 97 Teg
    California
    "Them valve clearances" isn't something that you just "hit up".
    Feb 2003
    89 LX-i 5 speed
    Madison, WI
    ohh okay well ill hit them up really good like then yeah ill make sure they are right!
    Atlanta, GA
    OK, old thread but sue me. I had the compression tested on my engine to see if the head was milled down, it wasn't. I did have a melted electrode on the 4th cyliner sparkplug, which got replaced. Unfortunately, the sound is still going on.
    Now, it wasn't going on when I had the '87 LXi engine in the car with it's 8.8:1 compression w/ my MSD ignition. Now I've got the 9.3:1 compression engine from an 89 SEi. I'm going to try a colder ranger plug and see how that goes, as I may be getting too hot of a spark and pre-detonating.
    1990/BMW/535iA
    New Orleans, LA
    The clicking you hear is slight detonation or pinging. It is usually a result of advanced timing. When you change to higher octane gasoline, the detonation point of the gasoline is higher, thus preventing pinging. You can try retarding the timing (if it is advanced) or use higher octane gas, which is less money friendly. Also, try to keep the engine within its powerband. I tend to shift at 2500-3000 RPM, which seems to be close to ideal for city driving. These engines don't produce much power in the low rpm, and most attempts to put the pedal to the metal at anything below 2000rpm result in pinging.
    Hope this helps.
    P.S.: FI engines tend to ping due to overadvanced timing only...carbs on the other hand can also do it as a result of a lean mixture caused by incorrect carb settings.
    3axap.
    Atlanta, GA
    The pinging happens at any RPM below 5,000. I'm already running 89 octane. For an engine of this age, 93 octane should not be needed for normal operation.
    As to the timing, advancing or retarding it does no good - still there. Now, that is not to say the sound doesn't get worse. You retard the timing completely vs. at normal or completely advanced, and it is quite a bit quieter. The vacuum advance is working fine, so I've ruled out a dying distributor. I'm not ruling out unusual carbon buildup in one of the cylinders, as this engine has yielded some odd surprises in the short time I've had it in the car (read my previous posts in this thread).
    So forth and so on....
    Feb 2003
    89 LX-i 5 speed
    Madison, WI
    hmm so it may just be some pre-detination? sheesh i dont want any of that in my car, i have been on vacation and still am (LA baby!) so i havent run outta fuel in order to put some higher octane stuff in yet.
    The wierd part about this whole thing, and why i started to notice it is because its started to get warm thus i can drive with my windows open and hear the engine more. i cant remember if it was doing it last summer and i knew a whole lot less about cars than i do now so maybe it didnt bother me.
    i did advance my timing quite a bit a while ago because it was at about 8deg instead of the spec 16deg however it still did it when i unplugged the vacuum advance hose which should drop the advance to almost nil, maybe its not predetination afterall?
    ohh well the higher octane gas shoudl tell me where my problem may lie and ill have to run that compression test sometime too
    1990/BMW/535iA
    New Orleans, LA
    Quote Originally Posted by johnwc723
    Unplugging the vacuum advance may or may not help depending on how far the timing is advanced in the first place. You are correct however, if the higher octane gas eliminates or decreases the rattling, then it is probably your timing. You may also want to adjust valve clearences. (less than a 2 hour job when I did mine the first time ) Also, make sure you are using the correct sparkplugs with the correct heat range. For our cars NGK plugs seem to work quiet well. Hope this helps.
    3axap.
    Atlanta, GA
    Between some higher octane gas, a range colder spark plug, setting the timing at completely retarded, and two cans of Sea Foam + 4 hours set time to clear the engine out, I got rid of the ping. I'm going to be driving in traffic tomorrow while in Atlanta, so I can test it then as well. I still haven't been able to check the timing belt, so I'm probably going to move it back a notch and see what happens.
    Experimenting - yee haw.
    Feb 2003
    89 LX-i 5 speed
    Madison, WI
    yeah im using the NGK standard V-power plugs right now pretty new too, yeah ill do those valves when it get s alittle warmer out
    and about that seafoam? you poured that into your gas tank or into your crankcase? sounds like it could be pretty bad for the enngine like that!
    Atlanta, GA
    Well, it wasn't bad. Car idles better at rest, starts easiers, and the acceleration is a bit more effortless. All it did was clean out the massive carbon deposits I had.
    Feb 2003
    89 LX-i 5 speed
    Madison, WI
    yeah my timing is at spec of 15deg btdc, so this is quite odd, maybe its my cold air intake suckin in too much air which combusts too much?
    next time i get gas its 93 and also im puttin some lucas gas stuff in there too since people say its good
  1. Shift Knobs & Shift Boots
    By ‹^› ‹(•¿•)› ‹^› in forum Interior & Exterior Care
    Last Post: 08-12-2003, 01:17 PM
  2. rattling when push down gas
    By kustom89lxi in forum 3geez Accords
    Last Post: 06-19-2003, 10:07 AM
  3. Rattling!
    By crxballer32 in forum Interior & Exterior Care
    Last Post: 04-04-2003, 04:36 AM
  4. Clutch pedal and shift knob vibration
    By ChthonicPowers in forum 3geez Accords
    Last Post: 09-29-2002, 09:46 PM
  5. muffler rattling
    By old86lx in forum 3geez Accords
    Last Post: 07-31-2002, 06:05 AM
