Results 1 to 6 of 6
Thread: Fuel Pump Problems
    Mar 2003
    Fuel Pump Problems
    I've got an 88 accord dx its carburated and stalls on me all the time. It used to happen only occasionally, but now much more often. When it stalls it has to sit for a few hours to over night before it will start again. I replaced the fuel cut off relay but it still stalls. I've replaced all the filters as well. After it stalls I can't here the pump prime. I was wondering if I could splice in an inline pump or can it not pull gas through the old pump. Or is it just eaiser to but a new in-tank pump in? Thanks. also what tools would I need casue the car is about a mile away right now. Thanks.
    Brett
    shepherd79's Avatar
    Falling Waters, WV USA
    you problem may be the fuel cut of relay.
    it is located on the back of the fuse box under the dash.
    i have some of them if you want.
    Mar 2003
    I got a few from a junk yard but it still stalls when I put them in. What does the cut off relay do anyway. Thanks
    shepherd79's Avatar
    it cuts off the power to fuel pump.
    did you check the fuses?
    Apr 2004
    Cousin had same problem. He replaced the fuel pump. Better off to get OE part. Changing this pump is much easier than instaling in line. Pump access is under carpet b/w trunk and back seat. Total time for job is 10 minutes.
    2.0Si User zero.counter's Avatar
    2006 Nissan 350z
    Does school count?
    If you use starter fluid, will it maintain an idle or just die out after a couple of seconds? Get an assistant to turn the ignition to the on position and you listen in the trunk for the pump to prime, do you hear it?
    If not, I have a brand new fuel pump for $50 shipped if you are interested...
    natsugusa ya
    tsuwamono domo ga
    yume no ato
  1. Fuel Assembly , Pump , & Fuel System Location
    By A20A1 in forum Carburetor Tech
    Last Post: 05-10-2016, 01:27 AM
  2. fuel pump problems
    By fur_fenton in forum 3geez Accords
    Last Post: 12-12-2005, 11:04 PM
  3. Problems with Fuel Pump
    By sedare in forum 3geez Accords
    Last Post: 09-05-2005, 02:54 PM
  4. Engine problems, maybe fuel filter or pump...
    By Trick87Accord in forum 3geez Accords
    Last Post: 08-08-2005, 07:03 AM
  5. Fuel Pump Problems
    By DCD1278 in forum Performance
    Last Post: 04-03-2004, 09:26 AM
