I have an 86 hatch DX and I just replaced both fuel filters, Air Filter, and the PCV Valve, and cleaned the carb. I replaced the air filter and cleaned the carb yesterday and it ran perfect, Today I got up and I finally got the PCV Valve out and I replaced both fuel filters.
After I did the fuel filters and PCV Valve, I started the car up to check for leaks, but the car died. So I waited and started it up again and it kept running, but the rpms were steadily rising by themselves until it reached 3,000. Then I waited, then tapped the gas and it dropped to just below 1,000. Then I put it in reverse and started backing out and the car just died. So I waited...Started the car up again and this time the RPM's were at just above 0!!! it was fighting to stay alive but it wasnt dying. What happened? I checked everything to make sure it was all tight but I couldnt find anything loose. Could the PCV Valve not be in far enough and cause this to happen or do I just need to adjust the timing ?
