"New" owner of old 88 accord lx w/, carb & auto. Car was running perfect until a fuel fill up. Car would not idle and has a miss all of a sudden. Car still accelerates good under med-high rpm w/out miss. When sloing down or stopping, if you're not pressing gas and brake at same time, it stalls. I have read hundreds of posts and tried everthing, including: fuel pump, both fuel filters, blew out fuel lines, new fuel cut off relay, coil, pcv valve, dist cap and rotor, plugs, timing, carb cleaner, reset ecm, and checked for vac. leaks. I'm not sure how thorough of a check I did for vac leaks. I used carb cleaner on the lines but found nothing. When looking into the carb while running, it seems that the gas coming out of the needle is trickling out under idle. When throttle is opened up, it has nice, uniform spray. The next thing I am going to try is the car crusher at scrap yard.
If you guys can't help, I'm screwed.
